Omega Help Area => Omega General Help => Topic started by: addy on 10 March 2023, 11:01:10
As the title says. Who make the best aftermarket track rods for Omegas? Febi, Trw, Myele or Lemforder or any other make, that anyone has good reviews of?
I know that I replaced a steering idler not so long ago on the Omega, with a lemforder. I ended up putting the original back on, as there was loads of play in the new one. So was wondering about the quality of their track rods. I have a loose steering feeling. The steering feels light and seems to wonder if I hit a bump or the road is not even. I have replaced all front suspension components, as the coils were snapped, wishbone bushes had gone. Centre track rod and the track rods were worn. It went straight through the MOT. (Before all the work was done, for the MOT. The car was great to drive, not even pulling to the left. Even with the worn and damaged parts). Cann't remember what trackrods I put on, but they weren't a crappy pair.
Thanks again for any help or suggestions.
The Omega can be really finicky.
Tyres and tyre pressure can play a part as can certain road surfaces. A poorly set up Omega might drive OK, and a precisely set up one on brand new components and decent tyres will drive better than new. But if one component is compromised enough to vary the geometry whilst driving then it will be all over the place.
Track rods are a service item, buy what you can readily get hold of and get the geometry reset. If the tyres are showing signs of uneven wear, then they too will need doing.
Thanks DG, for the quick reply. The strange thing is that there is no tyre wear. Will see about another setup check. Am I right in thinking the correct settings are as follows?
Rear Toe and Camber will be a compromise, but Thrust angle MUST be zero.
Front, Toe is +0° 03"
Camber should be -1° 10"
Or should the Toe-in be
Saloon . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0º10’ ± 10’
Variation with inner wheel turned in at 20‡ . . . . . . . . . 1º40’ ± 45’
No ifs or buts
The rear settings vary car to car as they have a single adjustment that does both camber and track. But it is fundamentally critical that the thrust angle is zero
The Omega is particularly fussy, and absolutely must have Thrust Angle of 0'00 only. Compromise the rear camber if necessary, even if its way out - though that's a sure sign the rear suspension arms are badly bent
Set the front camber to -1 degree 10’. Without adding weight inside the car. All the other angles will be OEM.
Thanks.
Addy
No ifs or buts
Thanks.
Addy
This. Same for the estate. :y
