Omega Help Area => Omega Electrical and Audio Help => Topic started by: Migv6 le Frog Fan on 25 May 2024, 19:13:30
Title: Cant resync key.
Post by: Migv6 le Frog Fan on 25 May 2024, 19:13:30
Second key for the Omega. Is rarely used. Last time probably two or three years ago.
Put a new battery in it today. Put key in ignition, turned to position one (also tried with ignition on) pressed lock unlock several times, nothing doing.
Could be battery connections inside key, but as it doesnt get used its hard to see how its got damaged.
Any other possibilities I can check ?
Title: Re: Cant resync key.
Post by: Doctor Gollum on 25 May 2024, 20:43:28
Is it a 'just purchased new' or 'sat in a drawer unused for two years' new? :-\
Post by: Migv6 le Frog Fan on 26 May 2024, 00:56:30
Came with the car seven years ago and has been on swmbos keyring, largely unused since then.
Tested voltage in the new battery and it showed just over 3v.
Post by: TheBoy on 27 May 2024, 17:54:21
Pop apart and check if batt connections are broken (where metal bit attaches to PCB).
Photo if not sure.
Post by: Migv6 le Frog Fan on 27 May 2024, 21:04:24
Will do. Thanks.  :y
Post by: Jimbob on 28 May 2024, 06:50:54
Ive a vague memory the fob resync only works with the door open, or closed...not either, and cant remeber which one...but only 2 options to try....
Post by: TheBoy on 28 May 2024, 09:49:11
I only ever tried with it closed, so never noticed ;D
Post by: STEMO on 28 May 2024, 15:31:01
You've never lived till you've tried it with the door open.
Post by: dave the builder on 28 May 2024, 17:01:03
;D
Or stood outside the car , reaching though the window  :P
Post by: Migv6 le Frog Fan on 28 May 2024, 17:48:27
I think thats called Dogging.  :D
Post by: dave the builder on 28 May 2024, 18:56:01
Nah !
All the people in the local park rarely have pets with them  ;)
they all seem very loving and affectionate  :)
though I don't know WHY they don't change the batteries in their car keys while it's light  :-\
always seems to be late at night  ???
Post by: Doctor Gollum on 28 May 2024, 19:14:31
Daytime is certainly much better, more people to potentially catch you jiggling your fobs... >:D
Post by: Migv6 le Frog Fan on 28 May 2024, 19:55:29
Anyway....................Im back in work friday night where I can insoect it under an illuminated magnifier, so shall take a look at it then.
Post by: TheBoy on 29 May 2024, 09:05:58
Is that like throwing them in a bowl with other people's keys?
Post by: ronnyd on 29 May 2024, 12:17:57
That's how it broke in the first place.  ::) :)
Post by: Migv6 le Frog Fan on 29 May 2024, 12:22:48
 :o ;D
Post by: Migv6 le Frog Fan on 01 June 2024, 14:05:40
Had a look at the internals under the microscope at work last night. Couldnt see anything obviously amiss.
Just been out to try the resync again but no luck.
I have discovered though, that it will unlock the boot ok, but does nothing with the doors.  ???
Post by: TheBoy on 01 June 2024, 18:08:45
So its sync'd then
Replace the switches
Post by: dave the builder on 01 June 2024, 18:10:42
so it will be the open/close buttons then
If the rubber case splits then "finger cheese " can get in the micro switches/buttons
washing with isopropyl alcohol (fob battery removed) can sometimes revive the switches
Post by: Migv6 le Frog Fan on 01 June 2024, 18:13:33
Had an Isopropyl wash last night. The case is in pretty good condition.
Anyone know a good source of switches please ?
Can hopefully get them changed at work, although my go to man has recently retired.
Both switches packed in at the same time though ?  ???
Post by: TheBoy on 01 June 2024, 18:26:42
RS, CPC-Farnell etc.
Post by: TheBoy on 01 June 2024, 18:27:25
Or in the good old days, the OOF Shop ;D
Post by: Migv6 le Frog Fan on 01 June 2024, 22:57:43
Yeah but - what to look for on the sites. Does it actually say 2 Vauxhall Omega facelift, key fob switches >
Post by: dave the builder on 02 June 2024, 10:31:30
ebay  :-\
 https://www.ebay.co.uk/itm/314819243037 (https://www.ebay.co.uk/itm/314819243037)
 https://www.ebay.co.uk/itm/172210435796  (https://www.ebay.co.uk/itm/172210435796)
Post by: TheBoy on 06 June 2024, 09:51:43
Or PM me you address and I'll post some
Post by: Migv6 le Frog Fan on 06 June 2024, 13:48:37
Had a set arrive in the post 10 minutes ago, but thanks.  :y
Post by: Migv6 le Frog Fan on 14 June 2024, 16:14:58
New switches fitted and key working as it should again. Happy days.  :)
Just need to find the problem with drivers side heating now. Theres always something.  ::)
