Omega Help Area => Omega Electrical and Audio Help => Topic started by: johansteibe on 18 August 2024, 13:48:09
Title: wont turn over
Post by: johansteibe on 18 August 2024, 13:48:09
my omega 2.0 from 95 wont turn over not even a click from the starter. the light on the immobilizer button on the central console will not come of and the central locking is not working any more ether
Title: Re: wont turn over
Post by: dave the builder on 18 August 2024, 17:32:59
try putting a new battery in the key fob and re-sync the fob  ;)
Post by: Doctor Gollum on 18 August 2024, 22:43:06
Isn't '95 the one with the separate remote fob? And no transponder chip :-\
Does the starter turn over if you apply power to it directly?
Does the dash light up when you switch it on?
Any resistance when you turn the key?
Post by: johansteibe on 18 August 2024, 23:48:46
i will try to apply power to the starter directly and see if that works and yes the dashboard lights up
Post by: johansteibe on 18 August 2024, 23:52:42
and ive tried to re-sync the fob but it wont sync even tho ive done it exactly as it says in the instruction manual
Post by: TheBoy on 19 August 2024, 08:11:12
If its a model year 95, it will have the infra red immobiliser system, where you have to start the car within a set time of unlocking the car.  The immobiliser system does seem less reliable than the later transponder based ones.
If it is that one, fortunately it can be easily bypassed.
Post by: johansteibe on 19 August 2024, 09:01:18
yes its the infra red system, how do i bypass it. i have not found anything on the internet on how to bypass it
Post by: TheBoy on 19 August 2024, 09:51:15
Prove that it is the immobiliser first, then I'll dig out the details ;)
