Chat Area => General Car Chat => Topic started by: STEMO on 05 December 2024, 12:02:22
Title: Check your insurance policy now
Post by: STEMO on 05 December 2024, 12:02:22
https://mol.im/a/14153617
Title: Re: Check your insurance policy now
Post by: Mr Skrunts on 05 December 2024, 13:16:43
Fair point, but I have never seen it as a tick box when I have renewed my insurance.
Post by: YZ250 on 05 December 2024, 13:19:38
They must have access to the manufacturer original build list then (not difficult I grant you), as some vehicles have hidden towbars. I’ve had a few BMW’s with electrically fold away towbar as standard equipment, the only give-away being the button in the boot (assuming that you’re not towing at the time).  ::)
I’ve also seen on the same website, that a hardwired dashcam is classed as a modification, whereas a dashcam plugged into a 12V socket is not. Anything to wriggle out of a claim I guess.  ::)
Post by: Mr Skrunts on 05 December 2024, 13:20:57
Also I reckon my tow ball has saved at least two possible claims at my last home. :y
Saw 2 different neighbors drive into my car whilst parking (Both women sad to say) one of which cost them a new bumper. ::)
Post by: Mr Skrunts on 05 December 2024, 13:25:02
So much is never covered on insurance (I didnt know about the dash cams) even though some mods would help with an insurance claim.
I hook 2 up in my car, I bought the hard wire kit but never fitted it. :-X
Post by: YZ250 on 05 December 2024, 13:45:30
Mine (front and rear cams) are hardwired in both of my vehicles so maybe I ought to give them a call.  :-\   If I’m lucky enough to survive the incident I suppose I could just remove it and tuck the wires under the headlining.   ::)
Post by: Rangie on 05 December 2024, 17:08:45
Always declared my towbars on all our vehicles that have had them, seemed a fairly obvious thing to do to me.
Post by: Varche on 05 December 2024, 23:24:58
Interesting article .Early next year, I intend having a tow bar fitted to our Spanish car.
Dockyard job. Find an authorised fitter. Pay for the job and then take it to government mot station where they OK it or reject. When OK’d it gets added to your vehicle documentation. If it isn’t there at your next MOT it is a fail. 20 years ago we used to regularly see incidents where trailers/ tow bars/ cars had parted company. Haven’t seen one for years since they tightened up the rules.
I am with Linea Directa ( same company as Direct Line) so will make sure they know.
We don’t see hardly any modified cars. The few that are I suspect are returned to factory spec for MOTs. You can get a fail for having tyres of a size not homologated or speed rating shown on vehicle documentation. I had to prove the mini facelift Elite 16 inch wheels were an Opel homolgated option when I put our uk car onto Spanish plates……
Post by: Doctor Gollum on 06 December 2024, 07:03:09
Find the factory option VW towbar and fit that.
My Merc one came from the in house parts recycler. Every part of it has a Mercedes and Oris part number along with the CE plate and all the mounting hardware was ordered from MB so it's as close to factory as it can get.
The DVLA had the foresight to issue the V5 with both the braked and in braked trailer weights.
Whether the car CofC needs updating is a secondary issue as the Towbar is covered by it's own as long as it's fitted in according with the factory installation documents via WIS even if it's self installed.
The car was built with all the installation points ready fitted. And there's not a single scotch block or twisted wire on the installation.
Point being the factory kit will go straight in whereas aftermarket will invariably require some level of bodgery.
Post by: Kevin Wood on 06 December 2024, 07:27:02
In don't know these days.. I fitted a Brink towbar to the Jag and it just bolted on like a factory one, and the supplied electrics was a CAN box that just plugged into the factory towbar connector and hooked up to a 7 pin plug on the tow bar. No bodgery at all.
Post by: Doctor Gollum on 06 December 2024, 14:03:12
Did Brink supply the factory ones?
It makes sense that the provision should be there if the car is type approved for it and therefore no excuse for it not bolting straight in, but..., likewise the electrics on a newer car.
Even the GM kit for the Omega was essentially plug and play. That doesn't prevent bodgery though.
Post by: TheBoy on 06 December 2024, 14:59:34
I think its fair really, its a modification and should be declared.  If there isn't a tick box, then that is no reason to assume it doesn't matter.  My old car was LPG, and not all insurance sites had a tick box for that, but I can guarantee you they would cancel the insurance in case of a claim.
Post by: TheBoy on 06 December 2024, 15:01:12
that a hardwired dashcam is classed as a modification, whereas a dashcam plugged into a 12V socket is not[/highlight]. Anything to wriggle out of a claim I guess.  ::)
Yes, dickheads with dashcams should have to pay an excessively high premium. In the same way that dickhead cyclists with helmet cams should be allowed to be run over.
They encourage bad behaviour.
Post by: STEMO on 06 December 2024, 15:14:09
Most helmet cams are worn by helmets  ;D
Post by: Rangie on 06 December 2024, 16:11:02
When I switched the Range Rover from LV to Aviva ( quote me happy ) motor insurance last year they actually asked me if the vehicle had a towbar , it made no difference to the premium I had already been quoted .
Post by: YZ250 on 06 December 2024, 16:13:31
Both Brink (Swan Neck) and Witter (Fixed Plate) had collaborations with many car companies when I worked in the car industry. They had access to the chassis design so would know all of the threaded fitment points, the clearance holes for anti-crush bushes and where spreader plates were required. Going back then, If you purchased a towbar from a main dealer, the box may have Jaguar/Audi etc on it but inside the box there would be a car company badged Brink towbar.
It’s not in the interest of car manufacturers to make towbars. My BMW towbars were factory fit but the actual towbar was made by either Westfalia or Oris.  :y
Post by: YZ250 on 06 December 2024, 16:30:58
I agree with the cyclist part of your post.  :y  ;D
As for the dashcam, I have it to record my impeccable driving standard.  ::)  I have never reported anyone and I’ve certainly never shouted whilst pointing at my dashcam “I’VE GOT A DASHCAM”.   ;D
Insurance wise, I’m guessing it would be double standards, where the insurance company would want to view the footage, find you NOT at fault but then argue over whether the dashcam was hardwired or just plugged in.  ::)
Post by: STEMO on 06 December 2024, 16:33:52
....and not be amused by your excessive speed  :P
Post by: YZ250 on 06 December 2024, 16:46:52
 ;D
That’s all in the past now.  :y
Post by: johnnydog on 06 December 2024, 17:11:04
My GM supplied towbar on my 3.2 Omega is an Oris....and when I wanted a replacement key for the detachable swan neck, my local Vauxhall dealer directed me to the Bosal factory in Bamber Bridge nr Preston (who have since closed a good while ago). I don't know the actual connection between Oris and Bosal though.....
Post by: johnnydog on 06 December 2024, 17:23:29
https://www.bosal.com/en/our-towbar-bicycle-carrier-history
To answer my own question, and for anyone that might be remotely interested.....
Post by: TheBoy on 06 December 2024, 17:27:24
In my experience, most mods don't actually impact premium, although might impact what is covered - eg, a new head unit probably won't increase premium, but it would no longer be covered for theft.
Post by: TheBoy on 06 December 2024, 17:31:16
 ;D
I heard you didn't pick up a single point, or any patronisation courses for weeks while you were cooped up in hospital
Post by: YZ250 on 06 December 2024, 17:40:33
In my experience, most mods don't actually impact premium  …………..
How about a remap with an extra sixty ponies, cat delete, adblue delete and six pot calipers? Asking for a friend.  ::)
Post by: YZ250 on 06 December 2024, 17:48:07
 ;D
  ;D
I’ve had a good run. I watch where I my speed religiously now, determined not to get caught again.  :y
Post by: TheBoy on 06 December 2024, 20:57:42
Yeah, that could ;D
Good job you are a reformed character, and don't need more than 100bhp....
