Omega Help Area => Omega General Help => Topic started by: Miotnir on 25 June 2025, 15:51:30
So i have an odd issue with the omega im tryna fix atm, i. Suspectic the torque converter have ruined the cluch packs ;(. but id love some help and if somone has had this issue before.
So all gears work fine, but when i press the throtle to gain more speed when im alreaddy in about 60-80kmh it drops a gear or two, but doesnt gain speed, give alot of noice but no power to the wheel, so i suspect cluch pack 2-4
Its a 2002 opel omega with a 2.2L i4 petrol and the gm 4L30-E 4 speed auto transmission, i kinda wanna avoid swapping the transmition, but at the same time wuld love if it wasnt the cluch pack, though i doubt il be that lucky :-\
However if its the cluch packs there will be a complete gearbox rebuild
Assuming fluid level is correct, at that stage in the UK, we'd replace the box - but spare parts from breakers are cheap here.
If you read the codes in the transmission, are you seeing a P0730 Incorrect Ratio?
i dont have a dedicated reader, but i checked with a reader from Würth, and it didnt read any fault codes, imma see on my closest auto shop that spesialize in opels and see what they have and if they can check for fault codes, but thats a 4h drive, about 250-300 ish km, so its not somthing i do any day, and espesialy not in the condition the car is in at the moment, its not in bad condition just atm need a anti roll bar link, and a new set of tyres
edit: i checked for a gearbox that i can get my hands on, theres one for sale thats relativly close, its in a junkyard, but its also about a 5h drive, around 350-400km, but i honestly think id rather rebuild the transmition than buy a new one, yes its more difficult but a valuble lesson
So i checked with a cuppe mates if mine, including an opel mechanic, and most likely its the torque converter, and posebly a burned cluch pack or 3 :P so eighter its swapping the gearbox and the torque converter, or its rebuilding the one i have, wich is easier said than done :(
The torque converters tend not to fail on Omegas. Not really anything to fail in them, assuming fluid level is correct.
The clutches do fail, particularly in the AR25. As said earlier, as we can get the gearboxes quite cheap in the UK, we just replace it with on from scrapyard.
You have checked fluid level? Although if've your had a lot of slip already, the clutches are shot.
So i did just check the gearbox for any identification, there is a sticker on the top but the ink is gone, there are alot of numbers and letters around the gearbox, but above the shift mechanism i found a plate that said its an ar25 gearbox, posebly an mar25, il look deeper into it but im unsure, i did also check the fluid level, it was too much, ab 1-1.5L too much, so that explains why it was leaking from the shift mechanism, though it didnt help, there is a lamp in the dash that more or less says that gear 2 is not avalible, wich is not entirely true, the main issue is that it dont wanna change gears when it shuld, had my suspicion with it being a 5L40-e with it being a dual pan, but didnt seem right, imma try and get a photo of the plate if not imma just note the numbers, but imma see if i can find a new or used one ;D
It's only a 4L30E...
https://www.xdalys.lt/en/product/13981212460/ starter for 10, but I would strongly recommend buying one from a 3.0/3.2.
AR25 is what it says, which is what was fitted to all Omega-B's except 3.0/3.2 and later 2.5TD
If replaceing the box, as Doctor Gollum says, try to get an AR35 from a 3.0/3.2
also (and please forgive me if you already know)the fluid level being crucial should only be checked with engine FULLY watmed up and running
Ill see if i can get my hands on an ar3535, but i cant garantee it, unless i import it or buy of sites like ebay, and yes i had been driving with the car for about 30-45 minutes trying to see if the gearbox behaved diffrently when warm, while there wasnt much change there was some, it actualy went abive 80 for once, while it was only to about 85-90 its a small bit of improvment since it only wanted to go up to about 65-70 when cold, but i still have the suspicion of a bad torque converter il lay it to the side for now, did find out that i can pull the gearbox from a saab 9-3 or an bmw e34/36, though i need to work with the electrical parts like ecu and tcu
A BMW gearbox will take a considerable amount of engineering and electrical work, that will be far more work, hassle and expense than sourcing and rebuilding an Ar35 that will be a simple bolt in.
The Saab 9-3 trans is for a transverse engine, front-wheel-drive car and will be of no use whatsoever.
Yea the bmw gearbox im aware of, but im also aware if that its alot more popular with bmws than opel omegas, theres posebly 4-5 omegas in the area, and 2 thats road legal, maby 3 if lucky, i forgot about that saabs are fwd, may posebly have gotten it confused in the moment. But i did look for a 4L30-E AR35 transmission and did find one for an mk3 isuzu trooper, while it is 4wd it might be possible to rebuild, though im not sure, and atm im not spending this monts rent money on a transmition, i may be bad with money but i try to limmit myself
https://www.ebay.de/itm/316996090261
Done.
Yeee, roughly a months rent, ill definitivly keep it in mind, posebly later this year, but first i need to get the car road legal again, (rust)
I just checked this yesterday, and not p0730 but p0780 and a sensor issue, so im looking at getting a new sensor to fix it
Hopfully that's all i need to do :D
