Chat Area => General Car Chat => Topic started by: Terbs on 01 August 2025, 19:49:30
Title: Changing a front wing
Post by: Terbs on 01 August 2025, 19:49:30
I am not happy !!!! Swmbo has stoved in the wing of the Omega. She hit the fence reversing into the drive. Not sure if it can be pulled out and filled, or whether it means a new wing.
What is involved in changing a wing (Facelift). I know it bolts on under the bonnet, but what else has to come off, and is there any welding.
I am not a happy bunny  >:( >:( >:( >:(
TIA
Title: Re: Changing a front wing
Post by: Doctor Gollum on 01 August 2025, 19:51:54
Nuts and bolts and about half an hour.
You around tomorrow?
Post by: Terbs on 01 August 2025, 19:52:57
Yes, but I haven't got a wing yet... I'm in Brackley now :y
Post by: Doctor Gollum on 01 August 2025, 19:58:59
Might be pull out able too.
Basically bumper end released, sill end unclipped, headlight out and two bolts to the A pillar, another one (or two) Infront of the door and two behind the bumper. Plus what you can see.
Car on ramps and wheel off/arch liner out make it easier. But car needs to be level and on the wheels when refitting just to ensure correct gappage ;)
Heading up that way after lunch. Pm if you like a hand/some guidance for what goes where ;)
That's not code for anything nefarious btw ;D
Post by: Terbs on 01 August 2025, 20:03:13
Not sure if it will pull out...it looks creased to me
Post by: Doctor Gollum on 01 August 2025, 20:07:47
You might be surprised  ;)
Post by: Terbs on 01 August 2025, 20:34:31
That explanation is very good, Al. Don't come out of your way to see it. I may just pop it round to a body place in Brackers to see what they say if it can be pulled. Not worried about having it painted, I was going to respray the wing anyway, as the lacquer is starting to peel.
Ill have to source a wing from somewhere, which will probably be the cheapest option. *Update*....My Grandson has just come round and said he will have it in his workshop and put a replacement wing on it. :y
Post by: Doctor Gollum on 01 August 2025, 21:43:57
It's not out of the way on the scheme of tomorrow, but sounds like you've got it in hand :y
Post by: Terbs on 01 August 2025, 22:15:36
Thanks for the offer anyway, Al, it was most appreciated. Evidently my grandson has a mate up north who has a wing I can have, no dents or rust, just need flatting and a respray :y :y Just a case of me keeping on at him to go and get it !! ;D
Post by: Doctor Gollum on 02 August 2025, 02:25:54
There might be one nearer you... ;)
Post by: Terbs on 05 August 2025, 15:16:23
Getting some quotes for a new wing, in case my grandson lets me down...one question....what's the difference between a prefacelift and Facelift front wing. ;) :y
Post by: Sir Tigger KC on 05 August 2025, 16:17:10
As far as I know Tony they had different headlights, so the cutouts will be different, and I very much doubt that they are interchangable.
Have you looked on ebay, to see if there are any Omega's being broken?  :)
Post by: Terbs on 05 August 2025, 18:51:12
Thanks Sir Tig....nothing on e-bay at the moment, but I have used a site online, and have half a dozen quotes ranging from £59 to £440, the latter is quoted as new inc vat and delivery. The first quote seemed a bit iffy on checking on them. Looking at one from a company called BCS Car Spares in Manchester, dearer but the company looks a bit better :y
To the uninitiated, an Omega is an Omega ??? ???
Post by: Sir Tigger KC on 05 August 2025, 19:26:54
That's a bold statement Tony!  ::)
The V6's were 'proper' Omega's and the 2.2's were for girls!  ;D
Post by: ronnyd on 05 August 2025, 20:56:59
Oi you!  >:( ;D
Post by: Doctor Gollum on 06 August 2025, 02:48:26
Nothing.
Post by: Doctor Gollum on 06 August 2025, 02:49:50
On the front end, the headlights, bumper and bonnet are different. That's it.
And all of those items can be fitted to facelift or age a car as a mod.
The only unchangeable differences between pre and post facelift saloon shells are the rear quarters and boot lid, although with time and money these can be changed too.
Estate shells are the same from '94MY to end of production.
Post by: Terbs on 06 August 2025, 10:15:34
Thanks Al....appreciated. So all front wings are the same. Brilliant :y :y :y
Post by: Sir Tigger KC on 06 August 2025, 10:23:53
I stand corrected.  ;D
Post by: Terbs on 03 September 2025, 13:18:27
Sorry to bump this up, but a quick question in response to Al's (DG) statement...half hour job....regarding the 'unclip the sill', I assume its possible to just unclip the front bit and not take the whole thing off. So again, I assume it can be prised off with a screwdriver. Just don't want to break anything :y :y
Post by: TheBoy on 04 September 2025, 08:46:17
From memory, its screwed at the front wheelarch, and underneath in a cuple of places, then brittle clips all the way along.
Post by: Doctor Gollum on 04 September 2025, 14:32:07
Turn the wheels to the side you want to remove.
Remove the screw at the front end and the round poppers from the bottom edge.
Tap the sill cover towards the front.
It will simply fall off.
To refit, place it in the correct position and clip back on.
Post by: Terbs on 05 September 2025, 15:10:17
Thanks fellas :y :y
Probably just me being over cautious ::)
