Omega Help Area => Omega General Help => Topic started by: danzigfan on 13 September 2025, 10:51:51
Title: Pulling when braking
Post by: danzigfan on 13 September 2025, 10:51:51
Hi guys, I had a 'little" misshap last year...I hit a concrete barrier with front right side. The wheel got also hit and from then on car pulls to the right when braking. I did full geometry setup twice, replaced bushings preventively, suspension has no play anywhere. Drives straight and doesn't wonder on the road, no shaking, no wobble whatsoever.
I'm puzzled, what else should I look into? Should I replace front brake calipers in case right one is sticking or grabbing force is different?
Thanks in advance, Stan
Title: Re: Pulling when braking
Post by: danzigfan on 13 September 2025, 11:05:48
(https://i.postimg.cc/nzknmH9V/IMG-20250913-114407.jpg) (https://postimg.cc/BLjW9fCR)
This was the damage
Post by: cam.in.head on 13 September 2025, 14:13:39
if the full alignment geometry was done correctly then this should have picked up on any alignment irregularities from anything unseen that  could have got bent in the bump .this should have shown if the subframe had moved or wishbone damage affecting the castor angle.i would have expected the camber to have moved ?but should have been reset anyway .
SO  and saying that it still drives and tracks straight we should be ok here
 next you need to be sure that the caliper is free as it should be AND comparable to the other side in respect of piston ease of movement,slide pins ,and any other obvious differences if any .you would think that pulling to the right would indicate a problem with the left brake realy but hopefully something should be obvious ,check for any bracket distortion too from
 the impact also worth swapping front wheels side to side too (unless tyres are directional)
w
Post by: cam.in.head on 13 September 2025, 14:44:25
so to sum up .
basically if the car drives fine untill you touch the brakes then this means one of two things .
either something is moving when you brake through wear,looseness or softness
OR  the brake is doing something different to the other side
Post by: danzigfan on 13 September 2025, 15:23:09
So the best option would be to go to mechanic or MOT place, whoever has the rollers where I could see braking force on wheels probably.
Post by: Doctor Gollum on 13 September 2025, 15:39:33
The alignment adjustment allows for a limited range of tolerance and does nothing to correct the position of the wheel relative to the axle centre line. If the right wheel is back from the original axle centre line then the car will pull that way when you add weight to the front end, ie under braking. An inspection brake test will rule out brake imbalance which is the road your mind is going down.
The following is belts and braces, but the critical point is that unde no circumstances do you take any measurements against a removable body panel.
If the wheel got hit then start with a detailed inspection and measurement of the front subframe mounting points. You'll need access to a four post lift and the tyre and tyre pressures must be identical to ensure an accurate height measurement.
Measuring the diagonals will confirm if the subframe is still square. Bolt to bolt.
Do the same with the chassis rails independently of the subframe measuring the length and height at both ends. The front where the reinforcement bar bolts on and where the rails end  on the floorpan.
Do the same with the top mount centre to the rear bolt of the opposite bonnet hinge and opposite upper/outer headlight bolt.
Do the same with the diagonals from the end of the chassis rails where the reinforcement bar bolts to the opposite corner of the lower radiator support.
If any of these are out by more than a few mm then the chassis needs tweaking straight.
If these all match up, within a couple of mm, very carefully inspect the bolt heads on the subframe mounts to see if there's and witness marks from the subframe having moved during the impact.
If there are marks then the subframe was hit hard enough to move it. Reposition it.
Replace the wishbones, struts, and wheel bearing and the wheel if it doesn't run true when spun.
Then realign it.
You could skip to the replacing parts section, but if the right chassis leg or subframe are tweaked, then you're wasting your time.
Post by: Doctor Gollum on 13 September 2025, 15:40:02
Only to rule out brake imbalance.
Post by: danzigfan on 13 September 2025, 15:43:30
Ok....will check brake imbalance first and then onto measuring the frame...Thanks
Post by: jb on 14 September 2025, 15:44:12
Wishbone rear bush allowing movement under braking
Post by: danzigfan on 28 September 2025, 17:14:13
Replaced both lower suspension arms and problem is fixed. Rear right side bush was badly torn and alowed movement when braking, as jb said. Geometry setup done again, I took poly bushes out of old parts and I'll leave it for some time in future.
Thanks for help
Post by: cam.in.head on 28 September 2025, 17:49:36
this would usually be the first port of call anyway but you did say you had replaced all bushes in your first post
Post by: danzigfan on 28 September 2025, 18:27:43
Language barrier, I'm sorry. I ment ball joints :-X
Post by: TheBoy on 29 September 2025, 08:20:23
Hey, your English is pretty good :y
Post by: Andy B on 29 September 2025, 10:00:24
definitely better than our Slovenian  :y :y
Post by: Webby the Bear on 04 October 2025, 12:41:52
Slightly off topic but I did my lower arms this morning.
Biggest help was buzzing the track rod loose. Much easier to pull knuckle/hub forward out the way so can put the arm in level.
Just thought I’d pass that on 🥰
