Omega Help Area => Omega General Help => Topic started by: Webby the Bear on 02 February 2026, 20:23:29
Title: WIM
Post by: Webby the Bear on 02 February 2026, 20:23:29
Hi guys, hope you’re all well.
So I’ve got loads of stuff done in the omega ready for the summer shows.
Following suspension parts being fitted it’s definitely knocked the tracking out. Went on WIM site and it appears they’re no longer going. Anybody know if they’ve moved elsewhere or that them just finito?
Title: Re: WIM
Post by: Migv6 le Frog Fan on 02 February 2026, 20:40:50
The chap who owned it died a while back.
Maybe it folded after that ?
Title: Re: WIM
Post by: Doctor Gollum on 02 February 2026, 20:59:55
Try Black Boots Tyres, Chesham ;)
https://www.protyre.co.uk/garages/black-boots-tyres-chesham-tyres-team-protyre
Title: Re: WIM
Post by: Mr Skrunts on 02 February 2026, 21:07:56
I thought WIM set up a network through out the UK
These I thought were linked to them but not 100% sure how far they branch
https://www.blackcircles.com/?gad_source=1&gad_campaignid=261736696&gclid=CjwKCAiAs4HMBhBJEiwACrfNZRthIUtXvJWlYwl6OhsYMNKRstMXPuynhrmV07_jy3fKjoAG-LKPCBoC-PIQAvD_BwE
Title: Re: WIM
Post by: Migv6 le Frog Fan on 02 February 2026, 21:13:40
Take the WIM settings to any place that has a Hunter alignment machine and insist they use those settings.  ;)
Title: Re: WIM
Post by: Valentin on 03 February 2026, 18:28:36
Hi guys, I'm looking for the correct settings too and I found this topic December 2013
https://www.omegaowners.com/forum/index.php?topic=119981.msg1524628#msg1524628
It sais
just found my last printout.. Target values are ...
Rear camber  -2º 05' +/- 0º 40' Cross 0º 00' +/-0º 04
Rear toe   0º 00' +/- 0º 45' Total 0º 20'  +/- 0º 10'
Front camber -1º 10'  +/- 0º 45' Cross 0º 00' +/- 1º 00'
Front caster  5º 40' +/- 1º 00 cross 0º 00' +/- 1º 00''
Track Diff angle -2º 00'  +/- 0º 45'
Front Toe 0º 05' +/- 0º 05' total 0º 10' +/- 0º 10'
Because I bought the car with alignment made 3 months before based on GM values I guess, here are the front tyres after 16000kms :D
(https://i.postimg.cc/kGzNKL5N/IMG-20260203-183815.jpg)
I will replace wishbones, drop links and rear track rods - fOr SuRe as our baguette président sais - then have to find a decent automotive geometry center.
But, are these values okay? Front camber -1º 10' seems a lot ???
Title: Re: WIM
Post by: Webby the Bear on 03 February 2026, 21:04:01
Tony Bones died? Shit didn’t know that 😢
Title: Re: WIM
Post by: Webby the Bear on 03 February 2026, 21:18:12
Just found post from 2022 about his death. That couldn’t have been much longer after I saw him last with the omega! Shocked.
RIP. Great bloke. And Wgat he did not know about geometry wasn’t worth knowing. I remember reading though his technical papers on his website. Unfortunately no longer accessible via WIM website.
Title: Re: WIM
Post by: Doctor Gollum on 03 February 2026, 22:54:46
It sais
Rear camber and track will fall where they can but the Thrust angle MUST be Zero.
Front  camber -1°10" no more no less.
Front track Toe in 0°03".
Front caster is variable but should be identical side to side... Tweak by moving the subframe if required.
Unless you like your tyres to end up like the last set.
Title: Re: WIM
Post by: RallyArde on 04 February 2026, 07:00:20
Regarding Doctor Gollums personal preference about the front wheels camber, for my experience there can be added little more negative camber to front without having uneven tyre wear. In my daily drive I´ve got 1´56 and in my V6 even 2, only problem that the car is too willing to turn in ;) ;D
A little example about the V6 from the last summer:
https://youtu.be/3YOsoQGfQeo
 8)
Title: Re: WIM
Post by: Doctor Gollum on 04 February 2026, 07:20:23
 8)
Those aren't my settings, but those that Tony created for the Omega at WIM, And yes, I used them on all my Omegas.
That your car is too willing to turn in tells you that the geometry is wrong. Set up right, the Omega is beautifully balanced. And perhaps more importantly, stable.
Title: Re: WIM
Post by: RallyArde on 04 February 2026, 07:34:21
 8)
Making the car more understeery doesn´t make it particulary more stable :-\  When your front wheels lose their connection to tarmac/road, you´re lose the incoming feedback as well.
Title: Re: WIM
Post by: Doctor Gollum on 04 February 2026, 14:06:50
 8)
With the fine tuned settings, I never found the Omega to be either understeery or oversteery. Just neutral and balanced, with just enough toe to counter the natural dead spot in the steering box
Making it turn in more easily makes it harder to remove steering lock. That said almost all my driving is on paved roads and not snow or gravel, so perhaps your geometry works better for that. :-\
Title: Re: WIM
Post by: omega2018 on 06 February 2026, 01:47:55
Can recommend Feltham Tyres www.felthamtyre.co.uk (http://www.felthamtyre.co.uk)
Title: Re: WIM
Post by: Valentin on 10 February 2026, 19:40:38
Hi guys, I took the time to illustrate the WIM settings on a standard diagram, applying the values found earlier on this topic. This can be helpful when you visit your favorite wheel alignment center :y
Everything seems okay except the rear total toe. The separate values are 0°00' +/- 0°45' right? How the total can be 0°20' +/-0°10' ?
(https://i.postimg.cc/W18vbjr2/WIM-Alignment-values.png)
Title: Re: WIM
Post by: Doctor Gollum on 10 February 2026, 21:35:13
For the rear, you are approaching it backwards, joke not intended...
The thrust angle MUST be ABSOLUTELY ZERO. NADA. ZILCH.
All the other values end up where they are.
Trying to set the values and expecting the thrust angle to be zero will never happen.
Title: Re: WIM
Post by: Valentin on 11 February 2026, 09:23:59
Ok understood.
For the values coherence, I took example on existing documents. If anybody find an error please tell me and I will apply correction.
Reminder of the WIM values found here https://www.omegaowners.com/forum/index.php?topic=119981.msg1524628#msg1524628
If anybody has them somewhere on his computer please can you compare and confirm they are the same ? Because I only rely on this link and still not sure if we focus on the right values.
(https://i.postimg.cc/sfNbqY19/WIM-Alignment-values.png)
Title: Re: WIM
Post by: Doctor Gollum on 11 February 2026, 10:56:05
A smidge too much front toe... Should be 0°03 each side.
