| Opening the inlet valve | |
| Earlier | Later |
| More power at higher rpm | Less power |
| More overlap with exhaust valve | More torque at lower rpm |
| Lower flexibility | Better emissions! |
| Poorer response at low rpm |
| Closing the inlet valve | |
| Earlier | Later |
| Less power | More power at higher rpm |
| Higher compression ratio at low rpm | Compression ratio improves with higher rpm |
| Better torque | max. torque in higher rpm band |
| More flexible engine |
| Opening the exhaust valve | |
| Earlier | Later |
| Less pumping losses, bit more power | More pumping losses,less power |
| Hotter outlet valve | More complete combustion, less emissions |
| More chance of pre-ignition | Lower exhaust temperature! |
| Closing the exhaust valve | |
| Earlier | Later |
| Less overlap with inlet valve | Part of intake mixture goes straight into exhaust at lower rpm (engine is "Off cam") |
| More flexible engine at low rpm | More high end power |
| Less power at higher rpm | Less flexible engine at low rpm |
| More torque at low rpm | Low torque at lower rpm |
| Improved emissions |
So for a race engine the inlet and exhaust valves must overlap for high end power( which explains their bad idle) .But how they solve the problem of low power for low rpms if turbo is not used..
My initial estimation is variable valve timing.. :)
QuoteSo for a race engine the inlet and exhaust valves must overlap for high end power( which explains their bad idle) .But how they solve the problem of low power for low rpms if turbo is not used..
There's one easy answer. Don't use low RPM! It's not a problem then. ;D
Race cars generally have a much closer ratio gearbox so you can keep the engine RPM high where you have the power.
Variable valve timing is handy where you want a wider power band because you can have a taste of both worlds.
Well written Mark.
PS Whilst we have Center Parks and Builders? Center we spell it centre here in Blighty! ;D ;D :y :y :y
As an engineer...... .....
Thanks for a great article Mark.
2 things come out of it for me...
A statement
That the gasses are moving so fast, their momentum is significant in valve timing. :o
A question
Is the effect of opening of the exhaust valve before BDC called "scavenging"? Or is that where the the momentum of the fresh mixture from the inlet pushes out exhaust gas around TDC from valve overlap?
Thanks again.
Quote....
You have letters after your name? 8-) 8-) :y
Engineers that do use them are usually salesQuoteQuote....
Of course, but i rarely use them!
QuoteEngineers that do use them are usually salesQuoteQuote....
Of course, but i rarely use them!engineerspeople.
The exception is Civil Engineers which pretty much have to be chartered to be able to practice. They usually use theirs.. CEng.
Where I am in manufacturing, CEng adds nothing except oldfashionedness. Which is a shame really as it is quite tough to get unless you have a Masters and a significantly responsible job to go with it.
If you have nowt else to do ..... ( and the stuff so far is brilliant .. :) )
I've never understood the theory behind the multi-ram system .. ie . how simply changing the length of the air-intake changes the torque curve .....
In the days of carbs the idea was as short and unobstructed intake as possible to get as much air in as you could !!!
Ahh ... penny drops !! so its the mass/velocity of the air AFTER the throttle bodies that matters .... in simple terms .. when we have a partially open throttle (restricted air in) we want to keep the velocity high to let the cylinders "breathe" easier ...
Do we have any requests for a topic anybody would wish covering?
Pretty much, if you read about the valve timing above, we want to ensure we get as full a charge in the cylinders as possible with max atomisation of the fuel........and that does not work at all well with slow moving air!
