		Chat Area => General Discussion Area => Topic started by: Danny on 02 October 2008, 18:31:01
				are there any cleaning solutions that will get oil off my driveway??
we have quite smooth paving slabs down, and its a recently built driveway so i doubt it'll be too tricky but i'm wondering if anyone has any proven easy methods?
				only one proven method m8
dont park car on it till oil leak is sorted
sorry not much help  ;)
				thinner,fuel or similiar solvent and after hot water with detergent..
				Gunk drive cleaner or is it path cleaner.
 I saw some in my local motor factors last month
				cheers, if all fails, i have a couple of spare slabs, i'll just replace :y
leak's sorted out :y
				Very difficult to get it off porous concrete as it soaks in! (which is what slabs and block pavers are!)
				hot detergent injection is a technique to produce crude oil from porous rock :y
				Tried most methods over the years including a good soak in TFR and then steam cleaning (not pressure) with an industrial steam cleaner and that still left oil remains.  :-/ :-/
good job i have spares......
i might even just turn the original ones over :D
complete cleaning is never guaranteed ;D :y
				We just used Swarfega when i was a steel faby to remove the oil stains on the floor near the saw. Tip it on neat & scrub away with a yard brush. It worked suprizingly well, but it wasn't engine oil though.
Worth a try if you can pinch some from work (i didn't say that)  ::)
