Chat Area => General Discussion Area => Topic started by: JamesV6CDX on 10 October 2008, 14:19:44
Title: Morrisons BioEthanol
Post by: JamesV6CDX on 10 October 2008, 14:19:44
I noticed while filling at Morrisons they sell a BioEthanol fuel - 15% petrol, 85 % ethanol.
It's 104.9ppl, so a penny cheaper than unleaded.
To convert, you need a kit to alter injection timings etc, which is around £600.
WHY!!! ?
Title: Re: Morrisons BioEthanol
Post by: Radar on 10 October 2008, 14:24:35
It makes no sense. They can't even play the green card since the method of manufacture is extremely inefficient and has pushed the price up of wheat/grain.
Post by: Marks DTM Calib on 10 October 2008, 14:33:13
So, its less efficient and only a penny cheaper.......
Post by: JamesV6CDX on 10 October 2008, 14:39:38
And also very difficult to cold-start on, which won't do the engine any favours!!
Post by: eddie on 10 October 2008, 14:39:42
Ah! but your missing the point,its GREEN,its got to be good for the planet,innit!  Ideal for Prius drivers.
eddie
Post by: Kevin Wood on 10 October 2008, 14:44:52
Difficult to see why you'd bother, TBH. :-/
It does look interesting for highly tuned engines due to the high octane rating (105 octane for e85 IIRC).
The fact remains that you'll get significantly less MPG even if the engine is properly tuned to run on it - which involves a sensor to detect the quality of the fuel and adjust accordingly, since you might need to cope with a tank of petrol, e85 or any mixture in-between.
A penny a litre won't compensate for that, so you are effectively paying for the opportunity to have more expensive bread. ::)
Oh, and certain materials in the fuel system don't get on with alcohol so you might need to replace quite a few parts during the conversion.
Post by: JamesV6CDX on 10 October 2008, 14:49:15
I think I'd stick with petrol or LPG! :D
Post by: Kevin Wood on 10 October 2008, 14:57:38
I must admit, I'm struggling to see how you can spend 600 quid converting to e85 though. Same ballpark as an LPG conversion and that's a complete new fuel system - ecu, injectors, plumbing, tank.
Surely E85 only requires some sort of piggy-back ECU, perhaps bigger injectors and a fuel quality sensor.
All for an allegedly greener fuel that's no cheaper.
Post by: platty on 10 October 2008, 14:58:10
So you would break even after 60,000 litres then? Sounds like a deal to me ;D
Post by: Kevin Wood on 10 October 2008, 15:08:05
I don't think you'd ever break even. E85 increases fuel consumption by up to 25% unless you have a very high compression engine, which precludes running it on petrol.
Post by: platty on 10 October 2008, 15:15:27
So to summarise Kevin, its a complete and utter waste of time?
Post by: Kevin Wood on 10 October 2008, 15:18:20
Correct. :y
However, if it were more widely available I'd be inclined to build an engine with higher compression and run it on E85 and LPG as a dual fuel.
