Chat Area => General Discussion Area => Topic started by: Martin_1962 on 18 October 2008, 18:49:48
What a pig of a job, very sore as well.
DOne the drivers side - now I have to do the passenger side, which looks horrible to do.
ANyway watching TV and I'll be back later and going to take some Ibuprofen
;D ;D ;D
Best of luck matey ;) ;)
I am sure you will crack it :y
All the very best Martin, as I am afraid to say you have get the worst side left to do! :'(
My advice is you tie all cables and pipes that you cannot remove up out of the way. That is the only way that I believe you can get the cover back on without disturbing the gaskets you have so carefully placed into position! :o ;)
OK watched Merlin - a bit of fun, anyway not too bad now, the back has survived, but dreading the passenger bank, last time I went there I broke the cable tray!
Also dreading my back conking out halfway through!
Good luck with it. :y
Done the drivers side, luckily the passenger side wasn't leaking... 8-)
.........whilst sitting on the engine.....not good, not a good thought at all Martin! :o :o :D ;)
Have fun! :D :y
I messed up a fleece supporting myself to avoid straining the back, bonnet is still up a bit as plenum is too wired to car and inlet manifold has too many cables to undo.
Just hope the cabling goes back easily when I refit as the last time I had the plenum off was to fit the cables causing the issue now (cut injectors)
Managed to use a piece of wood to fill in the gap between bonnet and alarm switch so if it gets lifted I will know.
Mainly sat on the slam panel!
Finished the passenger side around 10:30, just got the plenum refitted and no misfires so everything reconnected.
Just got to do the scuttle panel and wipers.
The sealant on the passenger bank will have until 14:00 to harden enough as I need to use the car!
Taken a long time as every half hour take a 10 minute break for back resting
just keep ploddin on :y
Well done mate :y
That is great news Martin, as it is always a great relief to see it finally all working again without complications! :y :y :y :y
My back is absolute agony now!
Go and have a lovely hot, steamy bubble bath and allow it all to soak away Martin in celebration of finishing yet another miggy job! :D :D ;)
Take that multi-ram shiz out and stand in there.
Im a tall lanky break with cronic back problems.
Doing the above saves me the couple of days worth of icepacks, that would often otherwise ensue.
I wouldn't fit - also have an undertray to remove!
Good luck, at least your half way there, :y
Try jacking the car up just enough so that you don't have to lean down so much but can still reach the rear of the engine.
i did drivers side, week later the passenger side went ::) ::) ;D ;D
