Chat Area => General Discussion Area => Topic started by: kris9128 on 01 November 2008, 15:57:00
the wifes astra keeps stalling. only does it when it gets upto running temp. anybody know what could be causing the problem. tired of her whingeing at me now.
what engine?, year?
oh yeah, sorry. 1800 on a V plate. have checked throttle body and it's rather dirty.
i dont know if this will help you but had the exact same problem on a cav sri, slightly older i know but on the injection side between the manifold i had a diaphram/vacuum unit [metal pot thing!] i changed that & it cured it, you might be lucky if the setup is the same ;)
1800 on a V plate
at a guess - the engine is to small ;D
cheers mate will nip out and have a look, are they expensive to replace
1800 on a V plate
it's plenty big enough for a woman
Missing some cylinders?
idle control valve at a guess mate ??
small barrel shape item located on side of the throttlebody ..
if the t/b is really mucky idle will be aswell ...
2 x small allen key bolts n pop it of (take care of gasket) fill with wynns carb cleaner and leave for 1/2 hr then empty & flush with wd40 and refit ...
use the wynns and a lint free cloth to do the body aswell opening the flap manually to get right in ....
should sort ya probs :y
looks like i know what i'm doing this afternoon then. cheers mate. ;D ;D ;D
1800 on a V plate
??????????!!!!!!!!!!!!!!**xxY%$ What!!!!!!! :o :o :o :o :o :o :o :o :o I hope your wife reads your comment and drags you by your short and curlies out of your cave! ;D ;D ;D ;D ;D ;D ;D ;D ;D ;)
1800 on a V plate
i wasnt meaning a woman of your experiance and capabilities lizzy. :-[ :-[ :-[ :-[
1800 on a V plate
Oh ok Kris, then I forgive you completely!! ;D ;D ;D ;D ;D ;D ;D ;D :y
i reckon you could have a 2 ltr ;D ;D ;D ;D
Typical bloke, you have to spoil it!! ::) ::) ::) ;D ;D ;D ;)
Anyway, back to your thread Kris, when was the Astra last given a major service? :-?
feb this year. but having been out and given it the once over it's looks like they didnt do naff all. air filter rammy, plugs rotten. oil needs another change. not fickin impressed. they even stamped the book. will order the parts and do it myself on tuesday.
That's what I expected Kris! ;)
Usually when an engine starts cutting out at low revs it often means dirty or blocked components, and what often sorts the problems out is a major service, with plugs, all filters and of course, oil, along with a good clean out of anything that can effect the performance. In the old days this included the carburetta, distributer and points which so often cured all ills. :y
This approach still does, especially when you do it yourself! 8-)
Airflow Meter?
try cleaning it carefully with carb cleaner
