Chat Area => General Discussion Area => Topic started by: Mr Skrunts on 20 November 2008, 19:45:33
Title: Advice Please - Home Alarm
Post by: Mr Skrunts on 20 November 2008, 19:45:33
http://www.omegaowners.com/forum/YaBB.pl?num=1227123966
With what has happened in the above thread then I think its time for an Alarm to be fitted
Any advice on Manufactureres to avoid/recomend.
I need coverage for 2 Bedrooms, hall, living room , kitchen, bathroom and 3 outbuildings that dont have power. (wireless - maybe)
Also looking into adding PIR security light with CCTV if possible.
I have a CPC/Farnell account but have no experience with alarm systems at all.
Any advice would be appreiated.
TIA.   :y
Title: Re: Advice Please - Home Alarm
Post by: dbug on 20 November 2008, 21:24:41
Know someone who had pro alarm system fitted + expensive security locks etc - villans went in thro brick wall!!
Post by: Mr Skrunts on 20 November 2008, 21:30:58
Sounds like they were defineately after something special there.
Post by: STMO123 on 20 November 2008, 21:31:43
Has your neighbours break-in spooked you?
Post by: Marks DTM Calib on 20 November 2008, 21:32:48
I really rate the Texecom ones.
I have a Texecom Excel setup which has been realy good from here:
www.alertelectrical.com
I dont rate wireless.....not one bit!
Post by: albitz on 20 November 2008, 21:34:39
over & under or side by side, both pretty effective. ;)
Post by: STMO123 on 20 November 2008, 21:35:32
Dont want to hear about your sex life thank you.
Post by: albitz on 20 November 2008, 21:36:58
I want to hear about yours though, do tell. :D ;D ;D
Post by: STMO123 on 20 November 2008, 21:38:33
Pervert!! :-*
Post by: albitz on 20 November 2008, 21:39:57
Touche. :y ;D
Post by: Mr Skrunts on 20 November 2008, 21:54:42
Not in the slightest.   We live on a juction whereby traffic coming off the estate looks right into his living room, he goes out evey night to the pub, out at work all day.  42" plasma on display at night when they are in as they  dont close the blinds and his computer is left on all the time by the front window.  Full alarm system, obviously not turned on.
Has UPVC windows but wooden doors which stick badly in the cold months so I get fed up of them coming in and out and banging the doors as they do so.
Now yesterday I heard a serries of noises (as I told the police) but thought it was them syruggling eith the doors, now had the alarm gone off then I would have been concerned and taken notice.
My reason for an alarm is that I am moving home in the new year and dont know the people in the new area, and as I know that people cant help but be nosy I know they will be scanning what I take into the new place with me.  I suppose the bit that puts me on edge is that it looks like a couple of chavs with toy corsa;s etc live there and without jumping to the wrong conclusion is that I would rather try to be safer than sorrier.
Plus I also get an insurance discount. ::) ::)
Post by: Mr Skrunts on 20 November 2008, 21:57:10
Am not a wireless fan at all (even on ADSL Modems) but may have to be a consideration for at least one of the outbuildings if only for a short period of time.
Hopeing I can get a panel that will allow it as an option.
Post by: johnnycboy on 20 November 2008, 22:14:08
Ive fitted this into mine  http://www.alertelectrical.com/Burglar-Intruder-Alarm-Systems/Alarm-Control-Panels/Honeywell-ADE-burglar-alarm-panels/ADE-Accenta-System-G3--8SP401A.asp.   Very versatile.  Full functional programming of 8 zones,  Added a digicom to mine as well for that extra peice of mind. hth
Post by: richardirv on 21 November 2008, 12:57:21
I would recommend wireless, but only if you are willing to spend a bit extra for a quality one, I have a Scantronic Wireless system fitted, I am 100% happy. Wireless keeps the instalation cost down and makes it very simple and easy to add more sensors to it. For example I have my shed alarmed and its as easy as pairing the PIR to the alarm then mounting it in the shed! you can even add pressure pads, glass break sensors etc. It also means you can have the main alarm controls away from the entry point and just have a simple keypad to enable & disable, this means there is no risk of people tampering with the main box. Another great thing I have put in is a Dialer, which once programmed can call preset telephone numbers and playback a recorded message to say the alarm has been triggered.
The only downside it you have to change the 2 AA batterys in the PIR's every 6-12 months. You need to make sure you get PIR's that once activated by heat, they switch off for 3 minutes or so. This ensures that the batterys last much longer than if it was constantly sensing.
