Chat Area => General Discussion Area => Topic started by: stuart30 on 21 December 2008, 14:48:19
Ive decided too put the car through its MOT next week....cant seeing it failing on much however the airbag light has come on (previously checked by mark and believe its the squib needs replacing.) and handbrake pulls a fair way up,it works and holds the car but quite a lot of travel.
Would the airbag light be a fail and would the handbrake be an issue or can the tester use his discretion and just advise on these. :-/
Don't quote me but thought the hanbrake was supposed to come up so many clicks
Yeah, its about 3 or 4 clicks to full on. Its not difficult to adjust.
Ken
http://www.welcomecar.co.uk/cars/mot.html
Great link that....
See you can be helpful when you put your mind to it ;D ;D ;D
Ken
Dont think ive ever had a car that was full on after only 4 clicks..... :o
STMO123 Regards link....Cant see dash lights listed.? (Hand link though. :y)
airbag light on will NOT! fail an mot
Ken
If they aint listed they aint checked ;)
A fault in a self diagnostic does not necessarily indicate a fault in the actual system.
Thats cool...... :y
Handbrake hopefully wont be an issue so fingers crossed it goes through....cant see why it wouldnt.
6 clicks on an Omega....4 is not enough and means the cable is probably not slack when released
More then 7 clicks then it fails its mot.you can tighten it up from the bolt half way down the prop but would really last very long
