Chat Area => General Discussion Area => Topic started by: JamesV6CDX on 21 December 2008, 18:53:45
Moving an LPG tank today, I think I must have put it down a little awkwardly, as there is now a small dent in the end of it, which wasn't there before.
Should I bin the tank? If it were internal there would be no question, but It's externally (chassis) mounted, and in reality, I'm wondering if it will cause a problem.
I'm also considering getting a third, larger tank for the boot, to accompany the twin torpedos. Anyone know a good supplier, for a 200litre bomb? ;D
Cheers
James
No
No
Nice to see you on form tonight Grandad...
No
That's no way to talk to the man who introduced you to your first facelift. ;D
If the dent's well away from the valve mounting or any welded seam I'd say it'll be OK.
It'll be OK James..........BOOM! OOPS. ;D
Yep - it's a good couple of inches from the weld :y
Maybe it'll "pop out" when you fill it up? :-X
Take some spare undies in case it does.
See if you can find someone to pressure test it to see.
Maybe try and have a word with Tylo.
don't suppose you know anyone with a pressure testing water tank? we had one at my last place for testing compressor castings until one blew at 60 bar and took out the rather windows ::) ::) ::)
seriously i'd get it tested if you can and it may 'pop' out like Kev says ;)
