Chat Area => General Discussion Area => Topic started by: Richie London on 30 December 2008, 12:05:28
its packed up. and its freezing in here. wont be out till monday now so hoping my m8 will have a look later, if not im gonna freeze to death in here, downstairs has gone away so no heat coming up from below :( :(
i think i'll take me lappie in the community garden, probably warmer out there :(
No gas fire? Stick the oven on :D
Fix it yourself....
what isn't working? boiler?
Fix it yourself....
Yeah Mark. And while he's at it he could do his cambelt and quickly build an extension. ;D
Fix it yourself....
Well why not....hes clearly not working today ;D
its trying to fire but seems like no gas is getting through. ive checked the meter ive plenty of credit. might have to get the barbie going in the middle of the lounge ;D ;D
its and ideal classic, total pile of pooo anyway, always going wrong. worse thing is i have to run the cold for about 5 mins before i can get cold water out. poxy thing
heating back on again, just after i did me cam belt and did a loft conversion as steve advised, my neighbout knocked, she has no gas, downstairs has no gas either. little b'stards turned all the gas off in the community garden meters, other ones are at front so they are ok. police have been informed and a community officer will have a word with them when he gets a chance. gas board have been told about this before by have done break all about it >:( >:(
That is good Richie to get your gas back so easily as it gets colder! :D :D
It is the kind of prank kids have done for years, but it still must make you bloody angry. >:( >:( >:(
As a kid we had no such thing as central heating......ice on the inside of the windows in the winter was common.
People today not used to hardship..........put another jumper on Richie. :y :y :y :y
Like wise.My kids thought I was making it up when I mention 'Jack Frost' :y :y with ice patterns on the inside.
The rented house my daughter shares with her mates near university has the heating paid as part of the rent. They have the temp set to 'tropical'. Consequently she's always cold when she comes back home to 'The Ice House' and wanders around in a T shirt. ;) ;) ;)
Indeed, the patterns were wonderful; but going outside for the loo and getting splinters in your feet from uncarpeted floor boards as you walked across them was not funny!! :o :o ;D ;D ;D ;)
Floor boards? ..... You were lucky!!!!!!! We used ....... ;D ;D ;D
I can see that this is going to end up as one of those "Monty Python"...........you don't know you're born ..........or When I was a lad we were so poor that........................threads. :y :y :y :y.
this needs to be stopped, its the 3rd time its been turned off outside, ive an electric fan oven so only gas is bolier. you get sick of complaining though thats the problem, nothing done :(
Can you remove the handle of the stop thingy? :-? That way they could not turn it off so easily. ::) ::)
Edit: I wrote Stop Co?k!!! ;D ;D
I wrote Co?k!!!
You hussy ;D
meter is half in ground half above, no key just a handle fixed on, and a plastic box surrounds it the kids use as seats, theve broke it off the bkts so they can move it about.
We had a similar prob, when i worked on a business park in Bristol......we had v. expensive main frames.....on test....we used to manufacture them....they needed a lot of cooling in the computer rooms....so the computer rooms had 5 or 6 air conditioners....running 24/7....the compressors/condensors were outside.....with the mains isolators next to them.....every now and then the local brats would come along during the night and turn the isolators off.....result was.....air temp in the computer rooms....rose rapidly....and basically the main frames cooked themselves....costing 10's of £1000 each time :(
The isolators had holes in them that aligned when turned on/off.....that could allow a padlock to fitted to stop being turned off/on....but health and safety wouldnt allow them to be padlocked in the on position.....but did allow a thin cable tie to fitted loosely.....so they couldnt be turned off.....but gave enough slack.....that an adult if they tried hard enough could break the cable ties off.
Could something similar be done to your gas valves?? :-/
Dog poo on the handle
We must have been lucky cos we had a rug in the middle of the floor and a small oil lamp in the loo to keep it above freezing.......... :y
Oh and rings around our legs, just below the knee where your cold wet wellies slapped your legs as you wore your shorts out in the snow...... ::) ::) ::)
It's true folk do expect tropical heat all year round now. Many friends houses are too hot for me this time of year, you walk in & can't breathe. I grew up in a 400 yr old cottage with sash windows. We had an open fire downstairs, storage heaters, & a fan heater we moved from room to room as needed, used to drag my clothes into bed in the morning to warm them up!!! Today i have the joys of double glazing & central heating but i switch it off before bed, can't sleep in a heated bedroom & i have my bedroom windows open 24/7 365. :y
