Chat Area => General Discussion Area => Topic started by: djdaveyp85 on 23 January 2009, 18:47:27
Title: My Vectra
Post by: djdaveyp85 on 23 January 2009, 18:47:27
I have finally decided to sell my 03 vectra (with failed fuel injection pump). Was just wondering if it is better to break it and sell the bits, or to sell the whole car as a non runner?
Title: Re: My Vectra
Post by: Danny on 23 January 2009, 20:09:23
what trim level is it? does it definately cost what you said it would to replace the fuel injector pump?
Post by: cem_devecioglu on 23 January 2009, 20:31:56
as a non runner will go cheap.. :-/
Post by: Danny on 23 January 2009, 21:04:02
if it's £3500 to replace the pump, its technically a write-off! :'(
Post by: Turk on 23 January 2009, 21:39:03
 £3,500  :o :o :o  Surely that can't be right ?
Post by: cem_devecioglu on 23 January 2009, 21:42:31
Any chance to find that pump second hand  ?
Post by: Taxi_Driver on 23 January 2009, 21:50:33
I agree.....that sounds far too much!
I assume its a tractor.....diesel pumps are loads more than petrol.....but even so.....i had a merc diesel fuel pump replaced (c220 td) by a merc dealer a few years ago.....and with flushing the system out (it had petrol put in it, hence why the punp failed) it was around £1500......i think the pump was around £800, the rest was labour.
Post by: tunnie on 23 January 2009, 21:55:51
even if the pump is an engine out job its won't be that much.... how much is the actual pump? and whats wrong with it?
Post by: Ken T on 23 January 2009, 21:58:35
Are you after something like this ?  http://cgi.ebay.co.uk/VAUXHALL-VECTRA-2-0TDI-52-REG-FUEL-PUMP_W0QQitemZ120327175022QQihZ002QQcategoryZ10404QQssPageNameZWD1VQQrdZ1QQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247
about £325, he should have the matching ECU for it.
Ken
Post by: tmx on 23 January 2009, 22:04:38
i just sold a friends vectra estate DTi with the same fault we got £360 on eGay for it
it was a 2000 W Estate in silver with 100k on it
its not as simple as replacing the pump! a Tech II is required and also changing a Chain driven diesel injection pump is highly skilled work so £££££££££
i can give you the details of the bloke who bought my friends he is a VX breaker who fixes the faulty pump problem
this is a common fault i believe with all 2.0 Di/DTi engines made between 1999 - 2004
Post by: Ken T on 23 January 2009, 22:07:24
Sounds technical  :P
OK, here's  a complete engine for £650 http://cgi.ebay.co.uk/02-08-VECTRA-1-9-CDTI-120-ENGINE-salvage-breaking_W0QQitemZ140294863003QQihZ004QQcategoryZ10404QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Ken
Post by: tmx on 23 January 2009, 22:09:10
That would be the ideal replacement if itll go in the older shape!
Post by: djdaveyp85 on 24 January 2009, 04:17:54
Sorry been at work, it's 2003 new shape vectra 2.2 DTi SRi the fuel injector pump has perished and it is £2500 for a replacement one fitted. It hasn't ever touched a drop of petrol always ran on diesel just decided it didn't want to put fuel into the engine one day. It has 132000ish miles on it and apart from that and a small dink on the front bumper it is in great condition. So what would you do? Strip it down and sell the bits, or sell the whole car?
Post by: r1 on 24 January 2009, 11:53:48
insured? procted no claims, go any matches ?no what i would do
