Chat Area => General Discussion Area => Topic started by: Gaffers on 31 January 2009, 19:07:31
Title: Learning how to weld
Post by: Gaffers on 31 January 2009, 19:07:31
I am thinking of getting a welding kit and learning how to so that I can build own trailer for the boat (much cheaper than buying one!)
I have my eyes on a lightweight inverter type (translation from German not sure if it is correct in english) as the chap sa that this would be the easiest to learn.  Is he right?  Anything I sld know?  I am quite handy and I learn quick so I dont see much of a drama.....
oh and its for mild steel
Title: Re: Learning how to weld
Post by: CaptainZok on 31 January 2009, 19:27:41
http://www.mig-welding.co.uk/ seems quite useful.
Whatever you do get a self darkening shade (£30/40 off eblag), if you try with the old green glass then use a self darkening you will wonder how you managed as it really makes the job so much easier.
You can see what you are going to arc onto rather than guessing till you actually strike up.
Post by: waspy on 31 January 2009, 19:43:19
Do you know someone that can weld & can give you lessons/tips?
Allways better to learn from someone that knows :y
Post by: Darth Loo-knee on 31 January 2009, 19:48:24
If you are learning to weld I would suggest learning with a MIG, quite easy :y
Post by: Tony H on 31 January 2009, 19:49:14
If your making your boat trailer yourself from mild steel it's well worth getting it galvanized :y
Post by: Vamps on 31 January 2009, 19:54:38
Sounds familiar ::) ::)
Post by: Darth Loo-knee on 31 January 2009, 19:56:40
Amateur :D ;D :P
Post by: Entwood on 31 January 2009, 20:02:58
Don't know exactly where in germany you are .. but most UK Forces bases, even overseas, have a "car club" which usually has someone who knows how and might be willing to teach you .. failing that .. station workshops or a REME regt near-by ?? In the UK I'd suggest an evening class .. most colleges do them and welding is usually on the menu ... no idea if Germany has a similar system ??
Post by: CaptainZok on 31 January 2009, 20:07:50
Amateur :D ;D :P
Least I don't need a toastie loaf when I start. ;D
Post by: Darth Loo-knee on 31 January 2009, 20:24:08
Amateur :D ;D :P
No mate you need two  ;D :P :P
Post by: CaptainZok on 31 January 2009, 20:25:38
"What's that burning smell Pete?" ;D
Post by: Darth Loo-knee on 31 January 2009, 20:27:46
It was his trainers when ran to get some water ;D ;D ;D
Fireman Pete :D
Post by: CaptainZok on 31 January 2009, 20:30:12
Told you before mate you've got to keep management occupied or their minds wander, which inevitably means more work for you. ;D ;D
Post by: Darth Loo-knee on 31 January 2009, 20:31:10
Tell me about it, got whip marks over my back ;D
Post by: Marie on 31 January 2009, 21:40:11
cool thats a great idea.
you can come practice on my exhaust if you like, i have a mini mini leak on a weld  lol
Post by: Ken T on 31 January 2009, 22:59:41
Gungum's a lot easier than all that welding business  : ;D
Ken
Post by: Kevin Wood on 31 January 2009, 23:41:19
I have been going to an evening class at the local college (Basingstoke). Just an introductory course, but it has been great so far. Guy who runs it is an ex-REME welder and just lets us play with whatever we fancy. No boring classroom stuff, just straight into getting your hands dirty with a but of tuition where it's needed.
Had a go at oxy/acetylene gas welding to start with, which I found a great way to start. Everything happens at a controllable rate and it's not unlike soldering, I found. MIG welding came a lot easier after that.
I got a 20 quid auto-darkening helmet from eBay and it's been a godsend. Having an extra hand available makes it so much easier.
Post by: dieseldean on 01 February 2009, 03:44:00
when batery dies on auto-dim mask you can still get a bad flash from an arc and it is the worst headache you can imagine for the following 2 days.
Post by: Andy B on 01 February 2009, 09:57:25
Had a go at oxy/acetylene gas welding to start with, which I found a great way to start. Everything happens at a controllable rate and it's not unlike soldering,  ......
If you can master oxy/acetylene then you'll be able to TIG too, same technique. :y
Post by: philhoward on 01 February 2009, 11:20:23
I was told that you know when you're good enough as you can write your name in weld...
Found Oxy-Acet very easy (but hade done soldering before...); took a while to get used to MIG though!
Post by: Kevin Wood on 01 February 2009, 16:17:07
Mine "fails safe" (goes totally black without power). Good idea to make sure the batteries are good before use, though, as I guess it's possible they'll go nuts with poor batteries.
I think he said they have a TIG welder. Might see if I can have a go.
Post by: ChevetteNick on 01 February 2009, 17:10:49
if you're going to buy a MIG welder get one that doesn't have a live torch as they're a real pain to weld with....normally the cheapest ones you can buy. buy a solar powered auto darkening mask, no need to worry about batteries then ;)
Post by: Andy B on 01 February 2009, 18:59:14
You're aiming to be able to weld thin-ish ally sheet!  :y ;) ;)
Post by: CaptainZok on 01 February 2009, 19:22:20
But not like this please.
(http://i107.photobucket.com/albums/m302/CaptainZok/WELDING.jpg)
Post by: Andy B on 01 February 2009, 19:24:29
hard hat
Gloves
eye protection .....
 :-?  :-?  :-? I can't see a problem!  ::)  ::) :y :y
Post by: CaptainZok on 01 February 2009, 19:27:30
Prob the norm in pie land. ;D ;D
