Chat Area => General Discussion Area => Topic started by: Martin_1962 on 09 February 2009, 21:35:53
For my fob repair I would liek to monitor the RF out, so would need a receiver.
Does anyone have an old or unwanted scanner they no longer want?
Or where I could get a kit I could build of one?
Thanks
Martin
I tried freecycle but they have changed their rules so I deleted all of my group memberships
Hi Martin, Give us a clue on frequency and band you need to cover !
Somewhere around 433.92Mhz aren't they?
Yes - I know there are a lot of electronics experts and magies on here so worth a go ;D
Will keep an eye out. 433.92 is within the 70cm amateur band. It is useful to get some confirmation that they are transmitting. The 3 different types have distinctive sounds too.
You can get little receiver modules for WT exempt bands. In fact, I think I might have one or two in the junk box. Will have to check....
Hi Martin,
not too sure what your trying to monitor and why?, Freq., Demod Audio, FSSK Data, Spectrum, O/P power, Signal Strenght?
Give us a clue?, Im a Radio Communications Engineer, might be able to help? :y
Thinking a little further, if you simply want to establish that it's transmitting you could knock up a simple diode detector probe which you could attach to the antenna strip on the PCB. Put a bit of gain on it and you could have an LED that flashes whenever it transmits.
I use a scope.....and a bit of wire as an aerial
Hi Martin,
Basically that it is transmitting and not just flashing the LED. I am not too well up on this - I am more practical level.
Sounds usefull :y
I don't have one of those either!
OK My electrical knowleage
I know what components do, I can read diagrams, I can tackle simple repairs and modifications, but I can't design a circuit or knock up somethink without instructions.
An example of my level is I was able to study the circuit diagram of a VCR, find a good source of IF, and mono sound, and a good place to reinsert stereo and also trigger stereo light, I had to solder 1 wire to one board, replace an interboard loom, cut one track and solder another lead back. I also fitted a load of phono sockets to the back panel.
Kevin and Mark are beyond me but I would understand if they took it carefully.
The simplest option for you Martin would be to buy a cheap receiver module i.e.:
http://cpc.farnell.com/jsp/search/browse.jsp?N=411+500001+1003120&Ntk=gensearch_003&Ntt=433mhz+receiver&Ntx=
and monitor the ouput with a scope or a simple LED.
Blimey! They're cheap these days. £3.92 for an AM module is a no-brainer really. Not worth messing about with anything else. LED on the output and job's a good'un.
It will probably get triggered by every weather station / car fob / wireless alarm in the neighbourhood but then again, you don't have to connect an antenna to it.
Tell me what I need and what else is required and I'll have a look :y
Hi Martin,
Maybe then a simple Frequecy Grabber / Finder, I remember buying one from Maplins a few years back for arround £30. it captures your Transmitted signal and displays Freq. and Signal Strenght.
Would have thought eGay for a second hand one would be a good place to start. :y
its the same as this Martin
http://www.ukmidlandscanner.co.uk/r2rev.htm
