Chat Area => General Discussion Area => Topic started by: bighed on 11 February 2009, 16:03:24
Title: Flashing sports light on senny
Post by: bighed on 11 February 2009, 16:03:24
Light flashed yesterday straight away after starting up, I turned car off and back on again and all was well. Been told it could be due to a gearbox fault and need it testing. Is there a way to paperclip a senny at all?  :y
Title: Re: Flashing sports light on senny
Post by: Andy B on 11 February 2009, 16:08:47
Yes!
But I'm at work and so don't have the web site with the relevant info. Ask on the ABS forum though & you'll get an answer.
You can 'paper clip the engine, gearbox, alarm, digi dash, ride control suspension.
Post by: bighed on 11 February 2009, 17:53:09
Yes!
Got member pack through 2 days ago and still waiting to be activated!!!
Thanks for info tho andy!!!  :y
Post by: Iain on 11 February 2009, 18:00:32
Yip paper clip it,under the bonnet,drivers side turret if i mind right,next to the fuel change switch....and count the flashes
I would source a gearbox ECU mate,common problem with them.....
Post by: Iain on 11 February 2009, 18:01:53
On another point mate,join the Total Carlton forum,as good as this one and most things are relevent to Senny's,a lot of good guys there too :y
Post by: Marks DTM Calib on 11 February 2009, 18:07:24
The VXON info for the cav will tell you which pins to short out.
Post by: albitz on 11 February 2009, 18:13:22
vaguely remember mine doing this and it turned out to be a relay in the relay box in the engine bay,dont remember which one though,it was a long time ago. :-/
Post by: bighed on 11 February 2009, 19:08:53
All info taken in. Thanks guys  :y
