Chat Area => General Discussion Area => Topic started by: Dusty on 26 February 2009, 10:53:42
I have just been to the shop to order a large OOF car sticker (24") but you only have the smaller ones available.
Can admin tell me if you will be getting anymore of the large ones in.
Thanks
Dusty :-* :-*
I would prefer the larger car sticker,but if you are not getting anymore in the smaller one might be OK :-*
Dunno if you care, but i think the small ones are internal stickers, the large are external.
Large ones withdrawn as it became apparent they are incorrect when fitted inside the glass...
If you have another use for them, rather than car stickers, we do have some
i had the large one's a while ago and fit fine on the outside of the glass
i might be getting a smaller one for the top of the front windscreen :y
TB I really wanted a large sticker, but if I have no choice then I will have the smaller one.
Am I correct in saying that the larger ones have been printed the wrong way round, and therefore will only stick on the outside. If this is the case would not the elements soon peel them off.
Nickv6 has said they are OK on the outside. :-* :-*
my car has been jst washed loads of times and sit fine on the out side
not peeling off or anything
just make sure the window it spotless before sticking onto the glass
(http://i490.photobucket.com/albums/rr264/nickandann123/DSC00282.jpg)
thats stuck on the outside and has been jet washed loads of times and its not moved
the omega bit looks a bit off set but on the car it is fine
strange
must be my phone
I'm going to take your advice on this one Nick and order the large one to go on the outside of the screen :y :-* :-*
I'll pop a couple up in the shop shortly, but the large ones HAVE to go on the OUTSIDE.
As to durability of this, no idea I'm afraid.
no MOT problems with it being in the middle of the rear windscreen?
I'd like to order the large one. How can I go about it? I'll take a chance that it will stick to the outside as Nickv6 suggests :-* :-* :-*
they will be fine tb :y
just make sure the window is clean as clean car be and its fine :y
nope no problems at all with mot's or police :y
Back in shop now
I have a large sticker on the outside of my estate window, it's not moved of started peeling despite it being in the wiper sweep.
Are you planning to get some more made with the correct sided stickyness TB?
no
I have ordered one thank you TB. :-* :-*
no
no
We do not think there is sufficient demand to be able to sell the minimum order quantities.
I'm more than happy to be proven wrong, but all the Admins need to be responsible with forum funds :)
