Chat Area => General Discussion Area => Topic started by: Miggy24 on 01 March 2009, 13:34:25
Hi all trying to fit them to my miggy for a show im going too.Only prob is i cant find anywhere i can fit them.Can anyone help :)
stick them to the roof :y
Under the passenger seat before you take the Mother in Law to the shops. ;D ;D
i fitted train horns on the inner panel between rad and headlights 8-)
Good grief :o I have had them on a Mini in the past ::) ::)
Be carefull in public road area's. They are illegal as far as I know.
Used to haxe set on me MK3 cortina gxl :D :D :D fitted them in side the engine compartment
plenty of room behind front grill or front bumper
Its ok now i have fitted them in the inside of the n/s/f inner arch.Im only using them for when i go to shows like track racing and run to the sun this year :y
I bought one of those Klaxon type horns, I was going to fix it to the car and whire it to the reverse lights but put a cut off switch in the cirsuit. I just get so pissed off with people who see you start to reverse and then walk arround the back of the car. So with the Klaxon I just thought it may help them walk faster especicially if they poop them selves when they here the hooter. ;D ;D
Well iv most of the fitting now all i have left to do is the wiring which should only take an hour or to.Might try and put a video up for you lot haha :y
have you got your horn's sorted
Nearly just need to do the wiring now :y
have you done your horns mate :question :y
No just need to wire them in ;D
