Chat Area => General Discussion Area => Topic started by: waspy on 07 March 2009, 21:54:17
The trigger gets very hot in a very short period of time on my Makita cordless drill & the drill fails to work. The battery holds its charge ok & the brushes seem to have plenty of life left. Could the trigger be faulty? Any ideas as to what's up or should i bin it?
ive got 4, i just replace the whole lot when something happens. i have a good 14volt dewalt drill with no batteries and no charger if you want it or anyone else wants it. also a 18volt metabo with no charger and a makita chop saw i stuck in the loft and have not bothered repairing
this is what you want, brilliant for use on the car, gets the tightest nuts undone in seconds
http://www.ryobi-direct.com/acatalog/18v__Impact_Driver_BID1801M.html
CD pete, take it to bits & see if there is a capacitor [i think it is] by the trigger, could be that thats gone fubar ;) failing that the trigger itself :(
Thank you mate :y
Was trying to get round to replying to you Pete but, been to busy!
Anyway, the trigger assembly houses the speed controller so that points to 2 possibles.
1) A short on the motor and or associated wiring.
2) A fault speed controller.
Pop it round if you want and I will give it the once over
