Chat Area => General Discussion Area => Topic started by: smartrs on 28 March 2009, 21:28:07
just serviced my 2.5 v6 , all i'd like to say is the was only one thing in the way t do the spark plugs ................................EVERYTHING !
Not to bad if you remove the two small torx bolts that bolts the cable tray into the plenum :y
Sorry its to late but you will know for next time ;)
Only on the passenger bank ;D
yer drivers side is now my favorite ;D
I did Tuckshops's cam cover gaskets and breather clean today - I hadn't realised how much extra STUFF there is on a 2.5 compared to a 2.6. Mind you, the driver side breather box is a hell of a lot easier to get to when the cam cover is off....
And thanks to Tuckshop for pointing out that the 'extra pipe' that I found at the back of the engine bay with nowhere to go was actually the central scuttle drain.... :y
