Chat Area => General Discussion Area => Topic started by: Vamps on 06 April 2009, 17:35:39
My Battery is now down to about 10 mins before it needs plugging in :(
I was using the 'performance' option which I have now just changed to 'Balanced'
swmbo says I have damaged the battery because I always use the laptop plugged in, she says I should flatten the battery more.
My argument is that I flatten the Battery every 24 hours because, when I first switch on I use battery power till it just about runs out, now down to just a few minutes.
What is the correct way to maximise battery life / power ::) ::)
If your using the Laptop mostly pluged, then take the Battery out when its fully charged (dont trip over cables, if its out).
I normally totally discharge and recharge once a month.
Simple Guidelines - assuming Li-ion battery
Avoid frequent full discharges because this puts additional strain on the battery. Several partial discharges with frequent recharges are better for lithium-ion than one deep one. Recharging a partially charged lithium-ion does not cause harm because there is no memory. (In this respect, lithium-ion differs from nickel-based batteries.) Short battery life in a laptop is mainly cause by heat rather than charge / discharge patterns.
Batteries with fuel gauge (laptops) should be calibrated by applying a deliberate full discharge once every 30 charges. Running the pack down in the equipment does this. If ignored, the fuel gauge will become increasingly less accurate and in some cases cut off the device prematurely.
Keep the lithium-ion battery cool. Avoid a hot car. For prolonged storage, keep the battery at a 40% charge level.
Consider removing the battery from a laptop when running on fixed power. (Some laptop manufacturers are concerned about dust and moisture accumulating inside the battery casing.)
If you have a spare lithium-ion battery, use one to the fullest and keep the other cool by placing it in the refrigerator. Do not freeze the battery. For best results, store the battery at 40% state-of-charge.
The worst condition is keeping a fully charged battery at elevated temperatures, which is the case with running laptop batteries. If used on main power, the battery inside a laptop will only last for 12-18 months. The battery pack does not die suddenly but begins with reduced run-times.
:-? :-? :question
That would be me then :-[ ::) and ofcourse that makes swmbo right :(
I have some Black and Decker gardening equip that is Battery powered, the instructions say to leave the battery on charge all rear round, guess different type of battery. :y
:-? :-? :question
Which bit?
:-? :-? :question
Which bit?
The cables bit :D :D
:-? :-? :question
Which bit?
No Battery in, Miss's walks across, trips on cable, plug gets ripped out of Laptop, no more oof. :y
Pretty much as dbug says - guessing thats direct from a manufacturer, seeing as they neglect the part that even looked after, they are only rated to about 500 charges (so 1.5yrs if you use it for a few hours every day).
This forum really is the font of all knowledge :)
Take care
Dave
:-? :-? :question
Which bit?
Now I understand, daughter managed that a couple of times.... :y
It's about 2 years old so I guess time for a new battery and look after it properly.
:y :y
Take care
Dave
It never ceases to amaze me what advice you can get on here. :y :y
I think we have most subjects covered between us :D :D
I was told too take battery off...only use when needed. :-/
