Chat Area => General Discussion Area => Topic started by: cam2502 on 06 April 2009, 13:44:56
Title: crappy laptop
Post by: cam2502 on 06 April 2009, 13:44:56
I have a hp pavilion ze4800 laptop that my mrs bought for me 3 years ago (£500). Instead of shelling out for a new one i want to know if i can add memory to it as its only a 256mb ram and i need at least 1gb. Is this possible and how much do you reckon that would cost me?
Title: Re: crappy laptop
Post by: zirk on 06 April 2009, 13:58:39
Not much, flip it over, undo the Ram Door and see whats what.
Post by: mathewst on 06 April 2009, 14:04:13
Not sure what memory actually goes in it.
I don't think that's a ddr2 (it's a bit old laptop so the old memory will cost a little more than for new ones).
And probably you cannot expand the memory beyond 1 or 2 Gb.
Why do you need at least 1 Gb??
Explain it a little and I'll probably be able to be a little bit more helpfull
Post by: hoj on 06 April 2009, 14:07:12
Loads of different items on ebay try 200232539052  for memory
Post by: omegadti on 06 April 2009, 14:16:50
Have a look at this link http://www.4allmemory.com/index.cfm?fuseaction=search.memorySearch&model_id=-5003
it tells you what memory you need - your computer will only take 1gb of memory so you might need to fit it in 2 512mb chips - try Spot-On computers in Manchester (mail order on the net - check them on Google) but shouldn't be much more than £10 per chip
Post by: mathewst on 06 April 2009, 14:21:39
Yep I checked it and your Laptop supports only old SDRAM.
Whatever you need the 1gb (Vista or something similar) it's just a waste of money because the CPU of the laptop is let's say barely ok but all the rest is fit for scrap if you plan to run anything that needs a fair bit of memory, hdd speed or vga usage
Post by: TheBoy on 06 April 2009, 14:48:33
[movedhere] Omega General Help [move by] TheBoy.
Post by: TheBoy on 06 April 2009, 14:49:51
I'd recommend crucial for memory.
But at 3yrs old, its tired, and at the end of its life...
(says TheBoy who's Tech2 laptop is about to have its 9th Birthday, and no matter how he tries, it won't die)
Post by: eddie on 06 April 2009, 14:58:49
Have a bit of fun and bung Linux on it!
Wife's DEll lappy (2yrs old) has just packed up-AC adapter goes out when plugged in. Output measured 35 volts whenI tested it-instead of 19.5!
When I contacted DEll's (cosmopolitan) Helpdesk I was assured that it needed a new 'Mainboard' at a cost of £185 +vat OR if I took out a new 2yr warranty for£150 they would knock 10%  of that price!  I think not >:(
eddie
Post by: TheBoy on 06 April 2009, 15:26:39
eddie
Hasn't got the memory to run graphical Linux. So unless you are a command line junkie, stick to XP with that little RAM.
Post by: Ken T on 06 April 2009, 16:07:00
Older laptops tend to last a lot longer than new stuff. I have just sold an Advent 7015 (P4-2.80Ghz) for a reasonable amount, still working well. My son's DV9000 just back from HP after getting a replacement motherboard fitted (Nvidia problems ) has died with the same problem after 4 months  :'( :'( :'(
Ken
Post by: cam2502 on 06 April 2009, 22:10:47
Thanks for your comments and advice guys. Think i'll bin it and get a new one! :-?
Post by: TheBoy on 06 April 2009, 22:18:08
will take 1G, and cost approx £65, plus the cost of an antistatic strap (don't attempt without, you WILL shag the memory (though think you've probably got away with it for a few months)).
http://www.crucial.com/uk/store/listparts.aspx?model=Pavilion%20ze4800%20Series
Post by: TheBoy on 06 April 2009, 22:18:40
obviously your choice if you think its worth it :)
Post by: cam2502 on 06 April 2009, 22:20:53
Just a though.....much would i get for it on fleabay do you reckon?
Post by: TheBoy on 06 April 2009, 22:31:50
Don't even go there.  At best, you may get an honest buyer and around £100. More likely you'll get scammed, and end up with no laptop and no money (and, yes, the scammers are clever enough to get the item and their money back (which Paypal etc will take back off you whether you have removed the money from your Paypal account or not, and are perfectly entitled to)
Post by: stuart30 on 06 April 2009, 23:56:44
As long as your caerfull then Ebay is fine...check the buyers feedback and that the address is verfied if they pay via paypal.
Doubt you would get much on there....£50/£70 maybe minus fee"s.
Post by: TheBoy on 07 April 2009, 19:22:22
Still leaves too many loopholes.
I'd avaoid egay for high value electronic items.
Post by: stuart30 on 07 April 2009, 19:29:25
Agree if its high value...besides probably get better deal else where.
But too be fair this isnt....i sold dozens of Toshiba laptops and never had any problems,couple of them were job lots £500 a time.
Well except a member from ""that car forum""... ;D
Post by: TheBoy on 07 April 2009, 19:46:25
you probably one those auctions yourself.  still, saves on postage....
Post by: stuart30 on 07 April 2009, 19:48:11
Tut tut as if....now who was it on here bought one from me....hmmm
They seemed pleased with it. :)
