Chat Area => General Discussion Area => Topic started by: zirk on 06 April 2009, 15:44:30
Title: Tartarini LPG Help - Not Miggy.
Post by: zirk on 06 April 2009, 15:44:30
Anyone know anything or had Tartarini LPG?, Need to get it in LPG False Start Mode.
Cut a long story short its on a BMW 318 which Ive been using for trips to London (Congestion Charge  :y).
I've managed to burn out the Fuel Pump (Petrol) whilst running on LPG with the low petrol light on :-[ :-[, why dont LPG kits switch off the petrol pump when running on Gas  >:( >:( >:(.
Any help regarding getting this fired up from cold on LPG would be good.
Title: Re: Tartarini LPG Help - Not Miggy.
Post by: Lazydocker on 06 April 2009, 16:05:18
Firstly... Someone should have warned you about the fuel pump thing... BMW's are particularly prone to this problem ::) ::)
Secondly, what system is it? Mixer/multi-point? Old/New? What's the switch like... Rocker (3 way) or push button?
Normally with a push button type switch you just hold the button when you switch on ignition and crank :y :y
Post by: zirk on 06 April 2009, 16:15:44
Sorry, should have mentioned that one, its a single point, Cert says it was done in 2007, black box under donnet says TEC 97, so quiet old, but does run sweet.
Small square'ish box with square push button. 4 green round leds + 1 red on top (fuel gauge), 1 round red led for petrol on left bottom, and yellow for Gas on right bottom.?
I can start it by squirting carb cleaner in the Air Intake, just a pain coz you need two people for that.
Post by: Lazydocker on 06 April 2009, 16:18:25
Right... So the switch is just a single push, which means it's electrical not mechanical?
Post by: zirk on 06 April 2009, 16:22:03
Electric, its not a latched or toggle, seems like the PCB type, push it once and it switchws.
Been messing with the switch before starting, no joy  :(
Post by: Lazydocker on 06 April 2009, 16:24:43
Electric, its not a latched or toggle, seems like the PCB type, push it once and it switches.
Just guessing here then... Before turning the key at all hold the button down... Now keep it held down until the car is running. This normally forces a gas start BUT... It will not switch automatically back to petrol!
Post by: zirk on 06 April 2009, 16:27:34
Trying it now!
Post by: zirk on 06 April 2009, 16:38:58
Trying it now!
Lazydocker, your a star, took a bit of cranking, started, wouldn't do it 2nd or 3rd time though, noticed if you hold the button in for at least 6 seconds on Ing. the flashing amber becomes lit and the red petrol goes out, Forced Start Mode on  :) :) :)
Well done that man, Beers on me when I meet you.  :y
Post by: Lazydocker on 06 April 2009, 16:44:02
Trying it now!
Well done that man, Beers on me if I ever meet you.  :y
Was just guessing really TBH... I know it's worked for both my LPG powered cars in the past :y :y :y
Be careful though, you no longer have the backup of petrol when you run out of gas! Obvious I know but just wanted to point it out ::) ::) ::)
Post by: zirk on 06 April 2009, 16:48:16
Well it was a good guess and it worked, nice one.  :y
Post by: Omegatoy on 06 April 2009, 20:38:19
bit late now but had a tartarini kit on one of my old sennys single point
and the emergency start on gas trick was to flick the button 4 times i.e. petrol gas petrol gas then leave it on gas and it would  start on gas then,
warning!!!!
 and when the engine is cold do not rev it as this is when the gas is not fully vapourised and can go BANG and take out the airflow meter but let it warm up gently and will be ok!! :y
Post by: zirk on 06 April 2009, 21:07:40
warning!!!!
Your warning has been noted Omegatoy, Thanks, Must admit when the petrol was working it would start on petrol and switch to Gas on pull away, or on a very slight increase in revs even when cold.
Must admit Im really suprised how well this runs for a single point, the only other LPG Ive had before was a veccy 2.0 eco factory fit multi point, it was really crap on Gas and seemed to make up the faults as it went along.  :y
Post by: Lazydocker on 06 April 2009, 21:30:52
warning!!!!
That's because it was a badly designed system... Vauxhall made a bad choice of supplier for their "Factory Fit" LPG option
Post by: Omegatoy on 06 April 2009, 21:36:20
warning!!!!
Tartarini system on my senny did 189000 miles with no faults except one hole in diaphragm in vapouriser and the parts supply was excellent ordered it from an agent in stourbridge and was there in two days :y had another tartarini system on the GSI which was varvale and was brilliant did loads of trackdays on it andnever a problem at all only thing i ever had to do apart from filters was every so often remove the top of the vaporiser and clean andpolish it as the gas used to build up a gunge inside the vapouriser which although it would run it wsnt happy on ful throttle, revved clean up to 7200rpm and power was down to 198bhp from 204 other than that brilliant!!
strangely enough its still going fine with the guy who bought it off me and has now done over 200k but the headgasket has gone so its parked up!!! :y
Post by: Martin_1962 on 06 April 2009, 22:39:17
Anyone know the Romano System N emergency start?
Post by: zirk on 07 April 2009, 00:59:17
warning!!!!
More stuff noted for the future!  :y
Post by: Taxi_Driver on 07 April 2009, 08:33:24
If you mean how you start it on LPG Martin.....its the same...
keep the button pressed down as you crank it.....i used to use to do that with my omega.....esp when i had the petrol pump pack up  ;)
Post by: Martin_1962 on 07 April 2009, 09:40:18
Tried it - gas light flashed, petrol light on :(
Post by: Taxi_Driver on 07 April 2009, 10:38:38
keep trying it, try leaving the ign for a few seconds first.
We had the same system, and it worked for me
I could get mine to start from cold straight onto LPG, was lumpy as break for a few min tho  ::)
Post by: zirk on 07 April 2009, 12:45:19
Martin, I originaly posted my problem on a LPG Forum without success (well done OFF'ers). One Guy on the LPG forum told me to try this thinking mine may be a Leonardo system. so give it a go, not sure how you gonna know weither it started on Gas or Petrol though.  :y
"it may well be with the age of car and the fact that it switches immediately it's started, that you have a Leonardo. If you do, and you'll have a control switch with a yellow LED on the left below the switch, a red petrol LED on the right and a row of 4 green LEDs along the top. If this is what you have, turn on the ignition, move the switch from gas to petrol and back to gas again, then start the engine without turning the ignition off first and it will start on gas."
Post by: Lazydocker on 07 April 2009, 21:50:35
TBH... He's possibly correct, if you had a rocker type switch!
That's why I asked what type of switch it was ::) ::)
Post by: Martin_1962 on 07 April 2009, 22:46:22
Mine is press button
