Chat Area => General Discussion Area => Topic started by: Lizzie_Zoom on 24 April 2009, 17:33:11
I want to upload old film photographs onto my PC, so can you tell me please what is an affordable way of doing this? Is there any particular piece of hardware that would do the job?
My system is: AMD ATHLON (tm) 64 x 2 Dual
Core Processor 5600+
2.81 GHz, 2.00GB of RAM
Physical address section
Loaded with Microsoft Windows XP
As I think quite a few of you know I know very little about PC's outside of using them, so all answers in English please!! :D :D :D :D ;) :y
Thank you! :-* :-*
I'M using a scanner-black & white laser printer- and photocopier all in one (scx 4100 old model)
father is using the new model
http://images.google.com.tr/imgres?imgurl=http://images.educational-software.com/productImage.html%3Fs%3Dmedium%26i%3D11510725.jpg&imgrefurl=http://www.educational-software.com/samsung-scx-4200-multifunction-printer-details.html&usg=__PGrYKxtQ1abz3bQMRda_SlhcOvo=&h=250&w=250&sz=7&hl=tr&start=16&um=1&tbnid=WRlnNsT0rQVW3M:&tbnh=111&tbnw=111&prev=/images%3Fq%3Dsamsung%2Bscx%2B4200%2Bprinter%26hl%3Dtr%26rlz%3D1R2GGLL_en%26sa%3DN%26um%3D1
its software is really easy to use for scanning ..Scans are very good quality and have useful one touch photocopy ability.. :y
flatbed paper feed is an important property in my opinion..So I didnt prefer cheaper models..
Thanks Cem :y :y
Will that set up give photo quality in colour? :-? :-?
there are all in one color models also..definitely more pricey..
http://www.superwarehouse.com/Samsung_Color_Laser_Multifunction_Printers/b/231/c/2743
Canon models are also worth checking..
Honestly I scan the old piccies but dont print them again..
Lizzie you can set the resolution when you scan the photo's. You can also crop them in case you have people/objects on them that you don't want to keep
Thanks Cem and Tommy! :y :y
An important note : there may be also inkjet style models..But in home use inkjet nozzles somehow dry up and create problem..So I I always prefer lasers..
Maybe worth going to somewhere like Boots or other photo processing place, and asking if they still have a facility to transfer film onto CD format.
Jessops are a camera place that used to do photo film to CD.
You get best of both worlds then photos which you can then copy from CD to your PC, and chop & change however you want ?. And still have the originals safely on CD.
If you Google for "photo film to CD" it may bring up places you've heard of that can do the transfer for you ?.
Don't know if that helps you out at all ?. :-?
M
M
Thanks for that :y :y
I know there is a digital picture processing / transference shop in our town, so perhaps that is an answer. ;) ;)
scanners have another extra ability ..when you scan printed documents you can also you OCR software to convert graphical text to useable original text format..so you can use them partially.. :y
Good point Cem :y :y
most OCR software handles well even with 300 dpi resolution..
Also I must note that Black and white lasers are also successful printing photos with grey color scale..Of course wont be same as color..but still good imho..
Lizzie.
Just thought of something, don't know if it'll help you ?.
There's a weekly (or could be monthly) magazine that comes out, called Computer Active. Explains all sorts of things in basic English, and they often have little projects that they explain in simple terms knowing not everyone out there understands tech jargon.
They also have a website, think it's called www.computeractive.co.uk.
If you use their search engine using 'photo transfer' it may bring up old articles online, which you could download (free from what I remember) that will explain about film to PC.
If you have no look, let me know via OOF, and I'll see if I can send you a direct link to the article (if they have one online ?).
M
Lizzie.
M
Many thanks M! :y :y :y
What sort of photos are they. Prints, negatives or slides ?
Ideally for slides and negatives you are better off (for quality) with a dedicated slide scanner.
ive got a epsom flat bed scanner ( can't remember the model number )
it scans photo's , slides, and negative's.
fantastic bit of kit and easy to use :y
the software cleans up anything it scans so you always get a great picture :y
just plugs into your pc via a usb cable
cost me about £200 but considering the amount of old photo's and negs around the house and the results then i think it's well worth it :y
Prints. ;) Negatives all lost. :'(
Because of the amount of photos i had to scan I bought an HP5530, it can batch scan 6*4 photos from a feeder on the top of the scanner. Saves a lot of fiddling about trying to get prints to stay in the same place on the glass..
http://www.amazon.co.uk/HP-ScanJet-5530-2400dpi-USB/dp/B0001OGNL0
Hi Lizzie (and others who maybe interested ?).
Just had a quick look for info, below links maybe a start (hope the links work anyhow), as I've just copied and pasted them ?.
http://www.computeractive.co.uk/computeractive/features/2236982/rescue-4111269
http://www.pcuser.com.au/pcuser/hs2.nsf/lookup+1/CC4D3101A19FF997CA2572820004CE14
The computer active magazine site maybe worth a look ?. If find anything else that maybe of some help to you (and others), regards info that I've seen or read, then I'll add to this thread.
I'm sure they'll be others who can help you to, as plenty of helpful people on here I've noticed :y.
M
Thanks Weds and M on the last two posts. Very useful information, as are all the previous comments and advice, which will help me to decide the best route.
:y :y :y
