Chat Area => General Discussion Area => Topic started by: JamesV6CDX on 01 May 2009, 18:33:35
I'm half way through rebuilding a V6 head...
All the stem seals I am removing, albeit high mileage, aren't showing any sign of wear whatsoever!
Found the manifold blows though - composite gaskets were used..... :y
Be better when it is finished.
When are you going to match up a 3.0 inlet divider?
I'm off to get a washing tray tomorrow (mine has gone) and I am going to clean the dismantled head, clean valves then commence the rebuild
Docs on there way to you James as we speak :y
Thanks mate - that is super :y
I thought problematic stem seals were limited to a small batch in the 2.6 / 3.2 era?
Yep, they dont wear normaly
And they will be heads 3 and 4 to do.
James ought to have a visit and I can show him how to port
I'm pretty sure in principle I'm ok on how to port - just not entirely sure on the tools people are using :y
That said, it would be good to pop up - you will probably want a hand lifting the heads onto the block, when the time comes...
(It can be done alone, but always easier with two...)
That would be 25-27 May roughly ;D
Thanks for the offer
Head porting, you need a file, round about 8mm or so, a minidrill is usefull for taking out lumps the files can't reach.
