Chat Area => General Discussion Area => Topic started by: KDXKiller on 04 May 2009, 17:44:01
Defecting Saab owner here, apologies..
Saab 9-3 with the same 2.2 diesel as fitted to the late model omega's.
It has suddenly devleoped a serious coolant leak from the vicinity of the bottom pulley, its dry above and i'm stumped.
My thoughts where that the only coolant in this area is internally in the water jackets in the block - hence my theory of a cracked block.
Given you chaps are more knowledgeable in this motor than the saab types appear to be - help or ideas would be appreciated, as a motor change is looking likely >:( unfortunatley..
cheers in advance :y
Theres an echo
WtF
Needs new Keyboard maybe :-/
took me several attempts to get it to post - didnt realise it had posted it twice - I've now deleted the the first post..
Apologies, anyway...
Fully functional keyboard in hand, back to the point lease ladies - enginey thing.. leaking, ideas?
There were 5 or 6 duplicates, now deleted, leaving one for replies. Hopefully someone will assist. :)
any takers for a spot of advice on water pump changing?
No doubt someone with more info on the diesel will be along shortly, only messed with petrol engines :-[
