Chat Area => General Discussion Area => Topic started by: Turk on 19 June 2009, 20:10:50
Title: Camber Guage
Post by: Turk on 19 June 2009, 20:10:50
What's the general opinion on this ?
http://cgi.ebay.co.uk/New-Sealey-GA45-Magnetic-Camber-Castor-Gauge-6-to-6_W0QQitemZ370172192991QQcmdZViewItemQQptZUK_Measuring_Tools_Levels?hash=item562ffb68df&_trksid=p3286.c0.m14&_trkparms=65%3A12%7C66%3A2%7C39%3A1%7C72%3A1689%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
Obviously not a patch on a full Geo at WIM etc, but as a reasonably accurate re-set tool when replacing front struts, it should be ok  :-/
Title: Re: Camber Guage
Post by: mantahatch on 19 June 2009, 20:30:29
Hmmmm, think you would have to ensure the front of the car was perfectly level for this to work.
Please correct me if I am wrong.
Post by: Turk on 19 June 2009, 20:53:09
For an accurate set-up from scratch the full weight of the car has to be on the wheels, but seeing as this guage can be Zero'd, I was thinking it would be fine for taking a measurment, Zero it, remove the suspension leg to change it or the springs and then re-fit and adjust camber to the Zero setting. Should be reasonably accurate until a proper full geometric set-up can be done.
Obviously if there is a camber issue to start with then it's not much use unless the guage can be attached to the disc with the full weight of the car on the wheels and even then it's not going to be as accurate as a proper Geo.
Just thought it looked pretty good as a temporary re-setting tool.
Post by: Andy B on 19 June 2009, 20:57:29
The link doesn't work for me!  :'(
Post by: Turk on 19 June 2009, 21:02:17
Hmm...nor me now !!! :-?
Post by: Turk on 19 June 2009, 21:05:41
Right, try the link now. I've replaced it with another.
Post by: Andy B on 19 June 2009, 21:07:02
Sealey camber gauge (http://cgi.ebay.co.uk/New-Sealey-GA45-Magnetic-Camber-Castor-Gauge-6-to-6_W0QQitemZ370172192991QQcmdZViewItemQQptZUK_Measuring_Tools_Levels?hash=item562ffb68df&_trksid=p3286.c0.m14&_trkparms=65%3A12%7C66%3A2%7C39%3A1%7C72%3A1683%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50)
Post by: Andy B on 19 June 2009, 21:08:17
[size=14]SNAP![/size]  ;D  ;D  ;D
Post by: iggy21uk on 19 June 2009, 23:28:01
Best camber gauge:
http://www.wheels-inmotion.co.uk/
Post by: feeutfo on 19 June 2009, 23:41:06
used an 11 mill socket as a feeler gauge between rim and shock when i changed my struts. subsequent set up was bog on....
obviuosly you need to find something that measures YOUR wheel strut gap set up before you start with this method, or however you do it. And also assumes your set up is correct before you start, which mine was...
Post by: Andy B on 19 June 2009, 23:43:30
used an 11 mill socket as a feeler gauge ...
1/4" 3/8" or 1/2"   ::)  ::)  ::) ;D  ;D :y  :y  :y
Post by: Kevin Wood on 19 June 2009, 23:59:51
You can measure camber just as accurately with a spirit level IMHO and yes, you need to do it on a level floor or zero the gauge against the surface you are on.
Cheap spirit level with a couple of holes tapped into it and 2 bolts does the job just as well.
Post by: feeutfo on 20 June 2009, 00:16:19
any of those for vx spec. ;D ;D :y
Post by: Andy B on 20 June 2009, 00:19:45
 ;D  ;D  ;D  ;D  ;D
Post by: Turk on 20 June 2009, 17:36:06
This guage is calibrated in one degree increment and decrement.
How do you accurately calibrate with a bubble between two lines and no calibration markings ?
Post by: Chris_H on 20 June 2009, 17:46:17
How about a protractor and spirit marker?
Post by: Kevin Wood on 20 June 2009, 18:44:05
With about the same accuracy, as I said...
Just because it will display to n decimal places it doesn't mean that's the accuracy you are achieving, especially when considering the effects of not having dead level ground, which you can do nothing about with either solution. 1 degree shifts the bubble in a spirit level quite a way too.
If you need to get it spot on, you need to go to a decent depot. Something that you can adjust on a DIY basis will reduce the amount of tread you use getting there after a wishbone change, or allow you to experiment with the settings once you have a feel for how your garage floor affects the readings.
Post by: Turk on 20 June 2009, 19:03:49
Oh definately. For a proper job it has to be a full geo. This would be used for when I change the springs for the up-graded std ride height jobbies I'm gonna have made at Faulkner's http://www.dfaulknersprings.co.uk/
There's a trip to WIM after, but that's around 200 miles from me, so I'll need to get things reasonably accurate.
Post by: Kevin Wood on 20 June 2009, 20:25:08
In that case, I'd try the spirit level method. Wind a couple of screws into the spirit level at the correct spacing so that they sit on the wheel rims. Set them to read level on a level surface and then screw the top screw out to give you the desired camber.
Amount to screw out = distance between screws * Tan (camber angle).
.02 gives you about 1.15 degrees, which is about where you need to aim for.
So, if your 2 screws end up 40cm apart you need to turn the top screw out by about400 x .02 = 8.5mm then adjust for a level indication when offered up to the wheel.
Toe is the setting that's a pain to get right.
