Chat Area => General Discussion Area => Topic started by: JamesV6CDX on 20 February 2007, 17:54:23
Thought I'd have a play tonight, at getting the leather seats to work. I followed Jaime's diagram, and hey presto, drivers seat springs into life!!
Lovely... I should be able to fit it all in tomorrow.... ;D
God job :y
excellent news James..... I was wondering about that.... whether in fact the seller was just too bone idle to check the fuse..... or had already disconnected the 12V feed while ripping something else out....
Well done that man ;)
Well done again James :y
Good news :)
Have you tested if seat heaters work yet?
excellent news James :y
I was a afraid the onboard seat ECU might have failed like on my project Elite.
I hope to see them fitted on Sat :y
Did they clean up OK?
Well done James :y
Just found the right cables, put them on the battery, and voila.. it works! Not cleaned them yet :S
Use proper leather cleaner....soap and water dries it out and makes it crack....
I have that same stuff you have, not the conditioner though.
What's the name of that stuff Mark?
What about soap and water, followed by leather cleaner/conditioner straight away?
This is the stuff I use.....soap and water will just shrink and dry the leather...
http://cgi.ebay.co.uk/LEATHER-SOFA-CHAIR-CLEANER-CONDITIONER-RESTORER_W0QQitemZ250071004694QQihZ015QQcategoryZ38210QQtcZphotoQQcmdZViewItem
Or, buy some of the disposable wipes from the super market, they dont clean as well as the stuff above but are better than soap and water.
You can use soap, but only saddle soap. As many horses as there are around here you ought to be able to find it, but car leather stuff is fine too. If it's been a while then conditioner is important.
DARN BLOODY BUGGER SH*TBAGS %"£$%"^ !!!
Just ripped out my cloth interior, fitted the leather. Back is all in and OK - front seat - out OK - went to fit the leather one.. it lines up Ok, but because the runners are different, it means the bolts for the rear are too short :'(
Did Tunnie not give you drivers seat bolts (we didn't have the others)?
lemme go look, if I could get three bolts in the seats, I'd driver carefully to the dealer for some more...
How many of the longer bolts do you have
I ended up using the shorter ones for the front and longer ones for the back
Worked a treat
Hope this makes sense :y
