Chat Area => General Discussion Area => Topic started by: Gaffers on 25 July 2009, 15:27:51
Title: MOT - exhaust
Post by: Gaffers on 25 July 2009, 15:27:51
I have just been getting the old girl ready fo rher MOT on monday and having not driven her for a while I had to get the jumper cables out, etc.  I noticed that there is a small but noticable blow around the center box area, I can hear it but not been under to find it yet.
Will this cause a fail?
Title: Re: MOT - exhaust
Post by: STMO999 on 25 July 2009, 15:33:10
If you can hear it without getting under the car I would imagine it will fail.
Post by: Del Boy on 25 July 2009, 16:01:54
Agreed.
Post by: Debs. on 25 July 2009, 16:30:13
I can hear my exhaust blow; from inside the house (with the door shut).....it`s stopped sounding 'sporty' now and has become annoying. :'(
Post by: Jimbob on 25 July 2009, 17:25:56
maybe worth trying one of these cheap stainles steel ones off ebay?
Post by: Gaffers on 25 July 2009, 18:17:41
Found the hole and plugged it with marine epoxy filler.  The exhaust will rot around that part of the box now but that bit will stay!  :y
Post by: KillerWatt on 25 July 2009, 22:01:02
The tester will check the system from the cylinder head, right through to the tailpipe.
If the system is not "gas tight" between those two points, then it will fail (if the tester is playing with a straight bat).
Post by: Robin Hood on 26 July 2009, 09:25:16
A couple of years ago I had a back box pass with a blackened hole the size of a fifty pence.  The tester told me he couldn’t fail it because it passed the emission test and was no noisier than normal.
He did fail the car on handbrake (off by 1-2%) but I sorted both for the retest.
Post by: Gaffers on 26 July 2009, 11:27:59
Well it's sorted now, and I have gone through the checklist.  The only thing it can go on now is emissions but seeings as she was super healthy last year I am not that worried (fingers crossed though)  :y
Thanks for your advice :y
Post by: Andy B on 26 July 2009, 16:16:47
http://www.motuk.co.uk/manual_710.htm  :y
Note: A minor exhaust leak from, for example, a connection joint or a pin hole, is not a Reason for Rejection
