Chat Area => General Discussion Area => Topic started by: lukie on 21 February 2007, 20:56:39
Title: Paperclip test ??
Post by: lukie on 21 February 2007, 20:56:39
went to my car this morning, it started a little longer than normal, went up the road and the engine managment light was on, got round the corner it went off, so my question is how do you perform a paperclip test ? will this fault be logged into system to read it back out ?
Title: Re: Paperclip test ??
Post by: TheBoy on 21 February 2007, 20:58:22
Code should be logged.
Read FAQ ;)
Post by: STMO123 on 21 February 2007, 20:58:30
http://www.omegaowners.com/forum/YaBB.pl?num=1152601768
Post by: lukie on 21 February 2007, 21:05:58
And my mission stops there.....
"Please note: After 1999 the chipsets were altered so it was no longer possible to flash the codes out this way."
Looks like it's back to ebay for a cheapo tech 2, guess this will do the job for my 2001 2.2 facelift
Post by: TheBoy on 21 February 2007, 21:13:42
DBW units (2.2/2.6/3.2) need a code reader...
I wonder if its a P0340 ::)
Post by: tunnie on 21 February 2007, 21:22:58
i have been thinking of investing in a cheapo tech2... I have a dell laptop with a real com port.
Something to treat myself with after uni and travel!
Post by: STMO123 on 21 February 2007, 21:28:07
You've got too much money, lad :o
Post by: TheBoy on 21 February 2007, 21:29:20
I dunno, he has the real thing a few hundred yards away, but still ain't happy....
Post by: tunnie on 21 February 2007, 21:40:52
i just like toy's...
in the summer, wash the car, check oil, coolant, tyres, and do a quick fault code read....
Unlike most students i don't go out on the piss every night!
Also no girlfriend  :'( - So that saves me hell of a lot of cash!
Post by: TheBoy on 21 February 2007, 21:42:40
Exactly what I was doing around 3pm today.
No fault codes in any system.... :y
Post by: STMO123 on 21 February 2007, 21:45:48
Yeah. But yer cant shag an omega ;D ;D
Did I just say that? :-[
Post by: tunnie on 21 February 2007, 21:51:00
 ;D ;D ;D ;D
As much as i like my Omega and my Senator.... there is something or shall I say someone else that has my affections!  :-[
And before any smart ass comments, its no one on this forum!  ;)
Post by: STMO123 on 21 February 2007, 21:53:19
Backside comments?  You're leaving youself wide open.
Oops, there I go again :-[
Post by: tunnie on 21 February 2007, 21:53:43
Exactly for the cost they are, it will be useful to have just to do a weekly check rather than annoy you!
Post by: tunnie on 21 February 2007, 21:55:42
 ;D ;D
Well I will close any possible opportunity's, she went to my uni and was in the year above!!  ;)
Post by: TheBoy on 21 February 2007, 21:58:40
 ;D ;D
And does she know?
Post by: tunnie on 21 February 2007, 22:03:50
 ;D ;D
And does she know?
Only a topic on paperclip tests could end up on this!  ;D ;D
I think so, been out for dinner with her a few times, been to her flat. She has just moved again. She is now living in Surrey, and works in central London.
I went and saw her at Made in Brunel, her project was very good. She said that she would visit me when I go too...
Its hard to tell what she is thinking (like all women!)
Post by: TheBoy on 21 February 2007, 22:06:36
Even for students, taking her to McDonalds doesn't count.... ;D
Post by: Kevin Wood on 21 February 2007, 22:24:33
Yeah. Imagine the riches awaiting a man who can design a fault code reader for one of those :o
Post by: Martin_1962 on 21 February 2007, 22:29:45
Try to impress her with your cars ;D
Post by: JamesV6CDX on 21 February 2007, 23:04:54
Tunnie, you dark horse....
STMO, you're right, you can't sh*g an Omega, but they're great for sh*gging in ;D
Post by: ClarCE on 22 February 2007, 08:56:30
lol, harsh.
Post by: lukie on 22 February 2007, 18:01:54
by chance I have figured out my EML problem, it is due to the gas conversion, I have ran now 500 miles purely on gas so the EM has lowered the oxygen sensor reading, therfore when running on the expensive stuff my car complains (and it's not the only one  ;D)
will have to run around for a few miles on petrol to sort it out, but just to note this is only happening as my car runs on a single point LPG conversion
Post by: Kevin Wood on 22 February 2007, 20:18:11
by chance I have figured out my EML problem, it is due to the gas conversion, I have ran now 500 miles purely on gas so the EM has lowered the oxygen sensor reading, therfore when running on the expensive stuff my car complains (and it's not the only one  Grin)
That figures. The petrol ECU doesn't know it's not providing the fuel. Over time it will adapt the fuel map based on sensor readings and its' adjustments may evenually hit the limit because it's not actually controlling the fuelling. Does the LPG system take an input from the Lambda sensor or the fuel injector outputs on the petrol ECU or does it just use a fixed (open loop) mixture?
Another way of clearing it might be to disconnect the battery for a while (or just disconnect the petrol ECU). It depends on the type of non volatile memory used by the ECU but this could well clear the correction values and restore it to defaults.
Post by: lukie on 23 February 2007, 17:44:52
as far as I know,  a single point takes a feed from the lambda sensor to monitor it's feed, it's a little strange, I start first thing in morning and EML is on, flick to gas it goes out, give it 5 mins switch to petrol and it stays out..... strange little thing, but hey saves me money on running cost's lol
Post by: Kevin Wood on 23 February 2007, 19:08:04
It could be that the strategy for Lambda control is slightly different between the gas system and the petrol system, i.e. it operates over a slightly different load / rev range. This might result in a small part of the fuel map where the petrol ecu thinks it's in closed loop but the gas ecu is not, therefore the corrections for that part of the map go out of range.
It's not a problem except that it might run a bit ropey when you switch back to petrol after using gas for a while but the ECU should re-learn the petrol settings pretty quick.
It might be worth taking it to an LPG specialist. The gas system probably creates a "false" Lambda signal for the petrol ECU when running on gas to keep it happy. Maybe the gas ECU settings can be tweaked to stop it. Then again, the petrol ECU probably won't go into closed loop until it's fully warmed up so why it complains at start-up I'm not sure.
