Chat Area => General Discussion Area => Topic started by: Selseybill on 03 September 2009, 14:22:14
I have tried to put my picture by my Id you see on the left but nothing happens.what am i doing wrong
Hi Bill,
You will have to host the photo on-line somewhere (Photobucket or similar). Once this is done then you can link the picture across to your profile.
Platty
i must be thick,put pics on photobucket brill but its given my 5 lists of codes http and alike .which one do i use :-/
You need to select the code that starts with [IMG]http://.......
Should work ok then. :y
i'll give that ago cheers
[movedhere] General Car Chat [move by] Auto Addict.
Are you sure Bobert? Not the 'direct link'? :-X
2nd link down it is
2nd link down it is
Wot he said, and I'd already said. ;)
As Steve has said, it's the DIRECT link you want, and it begins http:// (don't use the one that begins with [img]...it won't work.
It will also fail if the image resolution is larger than 110x110 pixels, and/or if the image file size exceeds 75KB
