Chat Area => General Discussion Area => Topic started by: moggy on 07 September 2009, 12:53:51
From all oof,s. I recently got made redundant after 20 years,and cant seem to find any jobs in my field.I then thought i have a driving licence i have held for 30 years.So i will try to get a driving job,i have a licence with categorys.B,BE,C1,C1E,D1,D1E,the problem is what can i drive on these.Can i drive an LGV vehicle because most of the jobs are for that.Also they want taco,and digi card how do you get them,any info greatly appreciated Moggy :-[
sorry to hear that..wish you luck for the new job :y
Wellung may well be able to help you there mate,as i recall him telling me he used to drive artics for a living. :y
Hi I am also unemployed at the moment, and also have a list long driving licence.
you can drive class 1 / 2 Lgv/Hgv, also waggon and drag.
You can get your digi card by getting an applicetion form from the post office or your local dvla ( the latter is easyer as you can talk to someone) your first card is free and lasts for 5 years.
hope you have better luck in your area for a job than me in my area.
Be very carefull with agencys as you only get paid for working when they have work.
Thanks cem,i have applied for over 50 jobs but no joy.I know others on the forum are in the same boat so good luck to them as-well :y
You can get your digi card by getting an applicetion form from the post office or your local dvla ( the latter is easyer as you can talk to someone) your first card is free and lasts for 5 years.Cheers gd will go over to po asap no work in your area then seems to be alot in birmingham
Thanks gd will get to the p/o asap, no work in your area m8 seems to be alot in brum
Sorry to hear about your bad news moggy. Hope you get sorted out soon :y :y :y
Bit far to drive though mate :y
With those licence classes you can drive goods vehicles up to 7.5 tonnes MGW and passenger vehicles with up to 16 seats IIRC.
Yes sorry stupid thing to say :-[,btw gd my mate just called he says on my licence i cant drive lgv/hgv you need a different licence :question
Kevin whats mgw :question
Maximum Gross Weight
Thanks zulu i will keep trying,the wife says im very trying ;D
MGW also known as maximum authorised mass (MAM), used in the context of driving licences, is the maximum weight of a vehicle or trailer including the maximum load that can be carried safely while used on the road. This is also known as gross vehicle weight (GVW) or permissible maximum weight. :y
you can only drive the classes which you have passed test on so if you only passed a car test you can drive a truck not excedding 7500kg MGW all the rest will be provisonail
So can i drive lgv/hgv like gd said provisonal(scuse a thick brummy) ;D
on your plastic card there is a list with pics of the vehicles, behind each vehicle there is a date as and when youve passed your test, you are allowed to drive these vehicles
for eg on mine I can drive the following
B, C1, C, BE, C1E, CE, M, L, and T/S
CE is artic
C1E is Waggon and Drag
C is Cass 2
C1 is 7,5
B is car
BE car with trailor
M is Moped
L is tractor
T/S motorised wheel chair.
Even on your paper part it should be stated what you are alloud to drive.
as you said you have
B, BE, C1, C1E, D1 and D1E
then you can also drive the above vehicles including ( as listed )
D1 minibus
D1E minibus with trailer
GD.So have i got this right,i don't have CE,which is artic and C which is class 2 on my licence.So i can drive all the others,but not those two,or am i still not getting it.(Dickhead i am) :-[
a bit long winded but should clear it all up.
http://www.direct.gov.uk/en/Motoring/DriverLicensing/WhatCanYouDriveAndYourObligations/DG_4022547
hope this helps :y
Cheers kris, but still not sure if i can drive artic or class 2.I will just apply for the jobs and see :)
If you dont have CE or C on your licence then you can not drive them, correct :y
you have C1 and C1E what means you may drive 7.5 tonn and 7,5 tonn with trailer.
you are correct in your thinking ( not a dickhead as you say) the licence is a bit difficult to understand sometimes.
you can apply for jobs as multidrop drivers or van drivers or where stated upto 7,5 tonn :y
You would know if you had take a test to drive a truck, all those years ago was HGV and you got a separate 'Cardboard Bookstyle' licence.
And the PSV was only a piece of paper.... :)
