Chat Area => General Discussion Area => Topic started by: Nickbat on 07 September 2009, 12:41:14
Title: Oil is not a fossil fuel...
Post by: Nickbat on 07 September 2009, 12:41:14
..well this theory, which I have mentioned in the past is covered in a new paper here:
http://climateresearchnews.com/2009/09/oil-is-not-a-fossil-fuel-and-co2-is-an-innocent-victim-of-green-hysteria-by-peter-j-morgan/
I must admit, I've always thought it strange that all those dinosaurs and so on would congregate to die in places like Saudi Arabia. And how come oil can be found 12km beneath the surface? I know it was a long term ago, what flora and fauna was around that deep?
Just a thought.  ;)
Title: Re: Oil is not a fossil fuel...
Post by: Banjax on 07 September 2009, 12:50:52
Just a thought.  ;)
nurse!!! the meds!!!!  ;D
Post by: Nickbat on 07 September 2009, 12:56:03
Don't be so quick to judge, BJ.  ;)
Post by: Banjax on 07 September 2009, 12:56:10
Nickbat - I know you don't believe this tosh - but thanks m8 for brightening up a dull Monday  :y
i may even buy the Mail to celebrate  ;)
Post by: Banjax on 07 September 2009, 12:57:58
are you serious? oil's a hydrocarbon - it the decomposed remains of plants and animals subjected to intense heat and pressure over millions of years - i'd love to see that recreated in a lab  ;)
Post by: Banjax on 07 September 2009, 13:00:20
mind you - whats fully synthetic oil then?  :-? ::)
is that what they mean?  ;D
Post by: cem_devecioglu on 07 September 2009, 13:02:40
Just a thought.  ;)
 ;D
 Peter J Morgan needs urgent attention me thinks ;D
Post by: cem_devecioglu on 07 September 2009, 13:06:35
from wikipedia..
Abiogenic origin
Main article: Abiogenic petroleum origin
A number of geologists in Russia adhere to the abiogenic petroleum origin hypothesis and maintain that hydrocarbons of purely inorganic origin exist within Earth's interior. Astronomer Thomas Gold championed the theory in the Western world by supporting the work done by Nikolai Kudryavtsev in the 1950s. It is currently supported primarily by Kenney and Krayushkin.[15]
The abiogenic origin hypothesis lacks scientific support. Extensive research into the chemical structure of kerogen has identified algae as the primary source of oil. The abiogenic origin hypothesis fails to explain the presence of these markers in kerogen and oil, as well as failing to explain how inorganic origin could be achieved at temperatures and pressures sufficient to convert kerogen to graphite. It has not been successfully used in uncovering oil deposits by geologists, as the hypothesis lacks any mechanism for determining where the process may occur.[16] More recently scientists at the Carnegie Institution for Science have found that ethane and heavier hydrocarbons can be synthesized under conditions of the upper mantle.[17]
Post by: Banjax on 07 September 2009, 13:12:56
what he said  :y
Post by: Nickbat on 07 September 2009, 13:23:06
If you're so clever, read this paper and tell me where they get it wrong. I'm not saying they're definitely right, but dismissing the theory as "tosh" in two minutes flat is not a logical, or helpful, response.  :(
Post by: Banjax on 07 September 2009, 13:30:03
i'm not dismissing it in 2 minutes nick,- its an interesting theory, but its been bandied about for years and never been proved - crude oil is a hydrocarbon - or are all the petrochemical scientists whose processes they use to refine crude into thousands of uses - are they just getting lucky or do they actually know the chemical composition of what they're dealing with?
Post by: Banjax on 07 September 2009, 13:34:02
don't you dare accuse me of being clever!!  ;D ;D
Post by: Nickbat on 07 September 2009, 14:21:46
"Our results support the suggestion that hydrocarbons heavier than methane can be produced by abiogenic processes in the upper mantle."
Anton Kolesnikov, Vladimir G. Kutcherov &  Alexander F. Goncharov, published in Nature Geoscience, 26 July 2009
http://www.nature.com/ngeo/journal/v2/n8/abs/ngeo591.html
Also
"Supporting Evidence, Briefly
Oil being discovered at 30,000 feet, far below the 18,000 feet where organic matter is no longer found.
Wells pumped dry later replenished.
Volume of oil pumped thus far not accountable from organic material alone according to present models.
In Situ production of methane under the conditions that exist in the Earth's upper mantle."
http://www.freeenergynews.com/Directory/Theory/SustainableOil/
Like I said earlier, I'm not saying that I necessarily believe it all to be true, but it's very intriguing and also somewhat logical. :y
Post by: Banjax on 07 September 2009, 19:32:34
Also
if we didn't explore every avenue - we'd discover nothing  :y
but this looks a dead-end  :(
Post by: Banjax on 07 September 2009, 19:33:07
Also
oils well that ends well  ;)
Post by: cem_devecioglu on 07 September 2009, 19:57:55
Also
Good work Nickbat :y
we - (not me, scientists) know that complex hydrocarbon molecules can be made artificially or synthetically..also I remember somewhere else I read in a big jar filled with hydrogen, carbon and oxygen elements (gas form)  under a specific pressure and temperature if you apply high voltage beams you can obtain simple organic elements very similiar to the beginning of earths history.. :-?
but unfortunately we need more proof to say oil is formed in that way..(scientists say, not me)
however if oil can be produced economically in that way I would be more happy than many people as the fuel is 1.30 here ;D :y
Post by: Nickbat on 07 September 2009, 21:17:20
Also
Thanks, Cem! :)
I can see you have an open mind to the possibility but, as you say, more definitive scientific proof is needed.  :y
Post by: OLDTIMER on 07 September 2009, 21:59:15
Just a thought.  ;)
If all the fossil fuels we burn today are reputed to come from the dinosaur era, how come we end up with tons of coal and no oil?
Is it because they would not have any use for coal in Saudi!!!! ;D ;D ;D ;D
Post by: Banjax on 08 September 2009, 03:55:19
Just a thought.  ;)
actually, we produce 1,690,000 barrels of oil per day in Scotland - more than Qatar, Ecuador, Oman, Syria, Yemen and Egypt  :P
source:U.S. Energy Information Administration
sorry, a bit pedantic i know - but it's late and i couldn't sleep  :-/
Post by: cem_devecioglu on 08 September 2009, 08:44:59
By the way, I must remind that all oil fields have a gas cap above it (under a salt dome as a natural trap)..
and also I know that most coal fields also have gas in it..
Post by: Dishevelled Den on 08 September 2009, 10:26:16
Just a thought.  ;)
say-what?
Post by: Banjax on 08 September 2009, 13:10:28
Just a thought.  ;)
say-what?
say what - what?  ;D
Post by: Dishevelled Den on 08 September 2009, 15:36:41
Just a thought.  ;)
say-what?
say what - what?  ;D
....splendid  ;D ;D ;D :y
