Chat Area => General Discussion Area => Topic started by: Rock on 05 March 2007, 09:05:04
Well today is the first MOT my Omega has had since i've owned it. Just dropped it off at the centre and I am now waiting nervously!!
finger nails shorten by the minute ;)
good luck :y
Good luck mate. :)
Hopefully you won't have the favourite culprit of a broken rear coil spring.
Good luck mate. :)
IIRC, its a 52 plate, so should be safe from that particular problem...
My car is a 2001/Y so does that mean i could have the problem??
Possible - the springs corrode.... ....nought you can do now, so wait at see....
About £70 for pattern springs, and about 1 - 2hr to change....
If they do need replacing, are they expensive?
see my post above ;)
Its like you are psychic!
Ok, so the news is that it FAILED!!!! :'( :'( :'(
Apparently the problem is with the front brakes, and a SEVERE imbalance!!!
He said the front discs are very worn, but not to the point that they fail. He said i need to change front discs & pads and that USUALLY cures the imbalance!
Does this sound right?
He described the imbalance as the worst he's seen in a long time, and yet i notice nothing untoward under braking...
Edit: Also is this part number 93175466 the right one for my brakes, and does it include discs & pads?
That PN is for pad/disc set. May have to get sensors as well, as they always break.
Oh yes, thanks for that! Do you think changing them will cure the imbalance?
If the calipers are cleaned up at same time, then probably...
Is there a How2 on here for Front Brakes? Also, would anyone please be able to spare me a TC card to get the parts?
It'd be worth checking the calipers aren't siezed while you're at it.
Try Autovaux as well
Check Maintenence Guides on this site. Its WIP, but should be enough there to help. Free up calipers as well.
Could someone please tell me what the current Retail / TC prices are for Front Brake Disc / Pad Set item number 93175466 ??
Got my local garage doing them tomorrow and I want to make sure I don't get taken for a ride!
How many hours labour do you think?
Cheers guys..
Kit retails about £100, and about £70 on TC IIRC. Both plus vat of course. Can't advise on labour time, but wouldn't have thought it would pose too many problems for a garage. For me on the other hand....... :-[
