Chat Area => General Discussion Area => Topic started by: Marks DTM Calib on 19 September 2009, 21:54:02
Title: Jimbobs Omega
Post by: Marks DTM Calib on 19 September 2009, 21:54:02
Completed the head change today.
All running very nicely, just a vac leak to sort tomorrow (the brake servo hose has worn through)
Title: Re: Jimbobs Omega
Post by: tunnie on 19 September 2009, 21:59:50
his HG went?  :o
Post by: Marks DTM Calib on 19 September 2009, 22:09:16
his HG went?  :o
Core plug on the bcak of the head has been weeping for some time but, its got worse recently!
Post by: Debs. on 19 September 2009, 22:13:17
...and there was I, thinking that Jimbob`s coolant leak episode was 'just' a hose gone! :'(
Post by: feeutfo on 20 September 2009, 03:09:46
good going in a day (i presume?)
how did the waterways look with stop leak used, any concernes?
Bushes? straight forward?
Post by: Marks DTM Calib on 20 September 2009, 19:28:22
Bushes done this morning, no real problems.
Coolant passages were all fine.
But, it threw the bloody cambelt. All was set correctly, all torqued up correctly(witnessed by Jimbob as the spanner etc) but, the tensioner released its tension (contitech - SKF).
So, its heads off and another re-build!
Post by: Auto Addict on 20 September 2009, 19:32:21
Post by: JamesV6CDX on 20 September 2009, 19:32:58
Was it a new cambelt kit?
Post by: Taxi_Driver on 20 September 2009, 20:03:58
No....second hand James.....i sold it to mr dtm.....carnt understand why it failed  :o....it had only done 39,999.9 miles  ::)
Sorry James...couldnt resist.....dont think mr dtm would mess about with anything 2nd hand to do with the cambelt on someone elses omega or even his own.  :)
Post by: feeutfo on 20 September 2009, 20:53:42
Oh!  :-? Very sorry to hear that.
Post by: JamesV6CDX on 20 September 2009, 21:01:32
what I meant was - did he re-fit the old kit.... silly...  ;D
Post by: TheBoy on 20 September 2009, 21:06:12
When Mr DTM replaced my HGs on the MV6 18 months or so ago, we decided to reuse the existing cambelt/tensioners.  In fact, only changed the cambelt a fortnight ago ;D
Post by: TheBoy on 20 September 2009, 21:07:17
Thats annoying...  :'(
Hope they brought 2 cars over so they're not stranded in deepest Nottingham until its fixed  :-/
Post by: Marks DTM Calib on 20 September 2009, 21:27:44
They got a lift back.....and it was a brand spanking new kit
Post by: JamesV6CDX on 20 September 2009, 21:29:54
Only leaves a faulty tensioner, then?  :-/
Post by: TheBoy on 20 September 2009, 21:30:04
Was thinking it was a bloody long way, but guess its actually not as far as it sounds
Post by: Jimbob on 20 September 2009, 22:34:24
A Huge thanks to Mark for a great weekends work, plus the prework refurbing the heads.
Such a shame it ended like this, was driving beauifully.
back end nicely improved with the donut bushes too.
Cheers to Bog Roll as well, offering a car at no notice to help us out, just wasnt really practical in the end.
My father in law drove up the 100 miles in his Vectra estate to rescue us, and I drove it home.
To expand on the pre-problems....
Core plug had been weeping for about 3 years, radweld kept this at bay fine.
Few months back, coolant loos massively ramped up, and chemicals did nothing, and no visible leaks, just a big smell of antifreeze all the time.
Then fortnight ago, it blew a newish HBV, replaced fine,
then blew a coolant hose of the bulkhead, so developed an assumtion of over pressurising.  So run with a loose header cap for a while, and lost more after any 'hot' trip.
So heads off, gaskets not in great shape.
Combustion chambers were VERY good, due to good petrol and regular doses of forte cleaner....photos to follow on that.
So thanks again
a great weekend, good fun, hard work, but good fun and learning, just so sorry you need to do so much again  :'(
Still, if it had to happen, better someone you know at your house, than someone else at a remote cambelt party etc
Post by: Marks DTM Calib on 21 September 2009, 08:26:46
24 Valves cleaned
16 Cam caps cleaned
24 sets of valve springs, collet bases, spring bases + 48 collets cleaned and ready.
Post by: Jimbob on 21 September 2009, 08:27:47
24 Valves cleaned
16 Cam caps cleaned
you dont mess about!
arent collets too small to go in the dishwasher  ;D ;D ;D
Post by: cem_devecioglu on 21 September 2009, 08:32:41
I'm following this thread with jealousy..  :'(
You are very lucky Jimbob.. :y
Post by: TheBoy on 21 September 2009, 09:48:01
24 Valves cleaned
16 Cam caps cleaned
I reckon they would go nicely on the pongs that hold plates upright....  :-X
The key is to ensure that all traces of car parts are removed before an old bag finds out  :-[
Post by: LJay on 21 September 2009, 15:56:18
100 miles door to door, so, far enough!!! :(
Looks like I'll be starting a new career as a taxi driver then!!!! :( ;D
Post by: Auto Addict on 21 September 2009, 17:43:18
Let me know when LJ, you make a cracking cuppa :y
Post by: TheBoy on 21 September 2009, 17:51:02
That was about what I thought it would be, but when I looked on map, it didn't look that far  :-/.  Guess the lack of direct roads doesn't help...
Post by: LJay on 21 September 2009, 18:09:25
Thank you! :y It's about the only thing I can do successfully in the kitchen!!!! :( ;D
Post by: Auto Addict on 21 September 2009, 18:10:53
I don't believe that, bet you can wash up ;D
Post by: LJay on 21 September 2009, 18:12:34
It's not a bad run, about 2 hours usually, when you can get out of nottingham and avoid muppets!!! ;D
Post by: LJay on 21 September 2009, 18:14:21
Ah! Due to the recent installation of a dishwasher I am gradually losing that particular skill! ;D There are less breakages too!!! ;D
Post by: TheBoy on 21 September 2009, 19:33:22
Being of the lesser sex, its OK for you to get lost in Nottingham :P
Post by: LJay on 21 September 2009, 19:34:36
I wasn't driving!!! :P :P :P
Post by: TheBoy on 21 September 2009, 19:43:50
I was referring to the previous time you got lost in Nottingham ;)
Post by: LJay on 21 September 2009, 20:46:52
Which one???
At least I had satnav to guide me home in mrs DTMs car!!! ::) And if that had failed at least I could have opened a window to ask for directions!!! ;D ;D ;D
Post by: Marks DTM Calib on 01 October 2009, 11:17:38
Ok, here are the bent valve pictures that I know you have all been eagerly awaiting!
(http://i23.photobucket.com/albums/b394/Marks_DTM_Calib/DSC00212-1.jpg)
(http://i23.photobucket.com/albums/b394/Marks_DTM_Calib/DSC00213.jpg)
Post by: Jimbob on 01 October 2009, 11:51:09
they didnt look quite like that when they went in!
Post by: Matchless on 01 October 2009, 13:22:27
5/10. Very poor attempt at bent valves, looks like you only managed a single bend in each stem, no sign of a proper 'S' bend on any of them.
Post by: Jimbob on 01 October 2009, 13:28:00
was only slow when it happened....he was just about to turn back into his road....
Post by: TheBoy on 01 October 2009, 18:02:31
Did it make it back under its own steam, or did you push...
Post by: Jimbob on 01 October 2009, 19:25:10
it just managed to coast back  :y....it had no power  :'(
and still doesnt thanks to incompetant courier firms  >:(
Post by: feeutfo on 01 October 2009, 19:48:54
bah, nout to do with slipped tensioner, somebodys  planted a bush in the end pot.  ::)
Post by: Marks DTM Calib on 02 October 2009, 08:25:37
If the gaskets arrive today, then I will start putting it all back this evening and hopefuly finish it off tomorrow morning.
After which, its on to Bobs car to do a lambda move and camcover gasket change!
Post by: Jimbob on 02 October 2009, 08:39:25
cool, ive just come off the phone from the courier - sent them the map and given the other postcode.
Fingers crossed!
keep me posted  :y
Post by: Marks DTM Calib on 02 October 2009, 16:08:53
N gaskets have arrived.....just checked with security, reception and goods in.
Hope the bike has a nice comfortable sadle on it  :y
Post by: Jimbob on 02 October 2009, 16:33:19
ahh well, never mind.
best laid plans and all that.
Post by: Marks DTM Calib on 05 October 2009, 22:12:33
Heads are on, B-bolt fitted, coolant pipe fitted, cams are in.
More tomorrow!
Post by: Jimbob on 06 October 2009, 07:14:06
More tomorrow!
good work  :y
hope those head bolts werent too bad on the old shoulder  :y
Post by: Marks DTM Calib on 06 October 2009, 09:43:02
The shoulder is very painful today!
Should get most of it finished this evening
Post by: Jimbob on 06 October 2009, 09:45:59
sorry about the shoulder :'(
excellent progress though  :y
Post by: Marks DTM Calib on 06 October 2009, 21:28:12
Engine all back together.....just the front pipes left to connect up (rain stops play)
Post by: Jimbob on 06 October 2009, 21:42:10
A good nights work!
been peeing down here all day, some massive puddles about
Post by: Marks DTM Calib on 06 October 2009, 21:44:02
Would have been finished.............if I could have found the bloody gaskets!
Post by: Jimbob on 06 October 2009, 21:47:23
I suppose the question is....how long will it run for this time  :-[
 ;D ;D ;D ;D
good test drive needed  ::)
Post by: Marks DTM Calib on 06 October 2009, 21:51:15
It will be fine, different backing plate and locktite!
Found the gaskets, 'somebody' had moved them into the garage....how the hell was I supposed to find them there!
Post by: Jimbob on 06 October 2009, 21:56:56
I thought that was tidy now  ;D ;D ;D
Post by: Matchless on 06 October 2009, 21:57:05
Oh the joys of fitting downpipes in the rain, scuttle drains are directly above them.
It also gets very wet disconnecting frontpipes when someone else decides to disconnect the heater pipes at the same moment.
Post by: Marks DTM Calib on 06 October 2009, 21:58:08
yes but, women don't understand garage etiquette and filing systems
Post by: Marks DTM Calib on 07 October 2009, 20:49:36
Ow rather HELL!
Post by: TheBoy on 07 October 2009, 20:50:05
Oh dear?
Post by: Elite Pete on 07 October 2009, 20:50:56
Ow rather HELL!
Uh ho, not again :-?
Post by: TheBoy on 07 October 2009, 20:52:03
Quick! Order another 24 valves!
Post by: Elite Pete on 07 October 2009, 20:52:48
And a panel beater ;D
Post by: TheBoy on 07 October 2009, 20:54:56
T-Cut may work :P
Post by: Elite Pete on 07 October 2009, 20:57:11
T-Cut may work :P
He's gone very quiet, I wonder if he's calmed down yet :-X
Post by: Marks DTM Calib on 07 October 2009, 20:58:00
I cant find my beer glass!
Cars fine though  ;D ;D ;D
Post by: TheBoy on 07 October 2009, 20:59:11
Sod the car:
a) its unimportant
b) its not yours (or mine)
Lost glass? Thats serious ;D
Post by: Elite Pete on 07 October 2009, 21:00:49
;D ;D
Post by: Jimbob on 07 October 2009, 21:10:14
Now thats a well earned beer.
I was never worried (cos I was talking to Mrs DTM and knew it was running  ;D)
Sit down and enjoy a few, you deserve them!
Thanks very much, looking forward to driving her again  :D :D :D
Post by: Marks DTM Calib on 08 October 2009, 11:25:53
Will probably drive it to the heritage centre and back tonight as an additional test  :y
Post by: Jimbob on 08 October 2009, 11:42:05
A very good plan  :y
She feel like she is running ok again after the mishap?  did you have time to port the heads again?  or are they stock?
looking forward to getting behind the wheel again I can tell you!
Post by: Marks DTM Calib on 08 October 2009, 12:15:13
A very good plan  :y
Running very quietly and your heat shields dont rattle any more!
Heads were again slightly ported.
Post by: Jimbob on 08 October 2009, 12:19:55
mmmm many thanks
I know time was short, good work fitting it all in.  :y
Post by: Marks DTM Calib on 08 October 2009, 12:23:39
mmmm many thanks
Well, it was finished 3 hours earlier than my worst case revised schedule (following delay of the gasket delivery).  It all went back together very nicely, about 3 hours!
So last night only took an hour.
Post by: Marks DTM Calib on 08 October 2009, 12:33:23
Aircon will be attended to this evening  :y
Post by: Jimbob on 08 October 2009, 12:34:04
good going.
So dissasembmly / rebuild was quicker 2nd time round with everything fresh and greased where needed.
and no SAI to get in the way of course  :D
Post by: Jimbob on 08 October 2009, 12:34:30
excellent  :D :D :D
Post by: Marks DTM Calib on 08 October 2009, 12:38:04
good going.
It was as quick as last time, the adder last time was the need to strip the old heads and bolt the ancillaies onto the re-furbed placement items.
Post by: Auto Addict on 08 October 2009, 18:07:29
mmmm many thanks
Careful Jimbob, sounds like it's been a rush job, cutting corners ;D
Post by: Marks DTM Calib on 08 October 2009, 18:08:31
mmmm many thanks
Nah, I only cut corners when doing pinion oil seals
Post by: Jimbob on 08 October 2009, 18:37:22
mmmm many thanks
and installing spring assisters  :y
Post by: Auto Addict on 08 October 2009, 20:26:06
 :P
Post by: Marks DTM Calib on 08 October 2009, 23:16:55
Aircon sorted!
Post by: Jimbob on 09 October 2009, 07:10:58
Aircon sorted!
'cool'  ;D
nothing more than a regas needed then?  :D
Post by: Auto Addict on 09 October 2009, 07:22:36
Aircon sorted!
'cool'  ;D
No, he's taken all the windows out 8-)
Post by: Matchless on 09 October 2009, 09:58:11
Aircon sorted!
'cool'  ;D
Vac, PAG oil, 950 grams of refrigerant and a thorough rag roadtest. :)
Post by: Jimbob on 09 October 2009, 10:17:09
Aircon sorted!
'cool'  ;D
Cheers Pete, much appreciated, Ill send the funds up  :y
Post by: Elite Pete on 09 October 2009, 13:37:06
Aircon sorted!
'cool'  ;D
Down ::)
Post by: Jimbob on 12 October 2009, 07:52:18
Ljay drove her back from Nottingham last night.
Said she was lovely to drive again, very quiet and smooth  :)
(gearbox dropped out, but to be expected)
I drove her to work today, and was disapointed to get there, would have stayed driving for a long time, great to be in her again.
She is driving very nicely, and seems to have a bit more poke too  :D
Huge thanks again Mark, youve saved her  :y
Will give her an oil change when I get home  (and again in about 1k?)
Deffo time to get my gearbox change scheduled in too  :y :y
Cheers  :y
Post by: Marks DTM Calib on 12 October 2009, 08:06:06
Keep an eye out for oil leaks, had a few problems fitting the drivers side cam cover gasket.
Glad shes running ok  :y
Post by: Jimbob on 12 October 2009, 08:07:43
Will Do  :y
Post by: SP_3.2 on 12 October 2009, 17:01:33
She lives good news :y
Post by: Jimbob on 12 October 2009, 18:47:41
Had a proper drive on the way home...
SO nice to be back in her, running really smooth and quietly
definately has more go, and the back end feels much more stable for those rear bushes, and to top it all, nipple erecting air con  :D
to add to a good trip home, walked into a VAT free invite for machine mart, need a few bits so come at a good time  :y
Post by: TheBoy on 12 October 2009, 19:12:27
Yeah, I have a vat free one about to expire, but my nearest is Coventry, so will probably go unused.
There is a bloody great void of Machine Marts around here :(
Post by: Jimbob on 12 October 2009, 19:55:10
I work 5 mins walk from one  :D
