Chat Area => General Discussion Area => Topic started by: Vamps on 14 October 2009, 23:55:01
Title: How do I add memory to a laptop
Post by: Vamps on 14 October 2009, 23:55:01
swmbo laptop is running slow, our PC advisor says it needs more memory, only go1GB??.  Our PC advisor did a great Job on our home computer, but does not want to 'fit the part' I think just in case something goes wrong, he has advised take to a computer shop.  Bless him, he is only about 14 years old..... Advice please.
No coments from anyone in stoke...... :P :P :P
Title: Re: How do I add memory to a laptop
Post by: CaptainZok on 15 October 2009, 00:11:00
Have a look at www.crucial.com Mike.
They have a little tool on there that will tell you how much memory you can fit and what type you need.
Fitting is usually simple, unscrew a flap on the bottom of the lappy or under the keyboard.
The memory just pushes into it's slot then clicks down into place.
Remember to wear an anti-static strap when you're doing it though.
Post by: Darth Loo-knee on 15 October 2009, 00:13:23
1. Obviously it is fast enough for you Vamps...
2. Think he was refering to you not the Computer...
3. Because he aint got a clue whats wrong with it...
4. Don't know anyone who lives in Stoke :P :P :P
Post by: Vamps on 15 October 2009, 00:16:02
He does not want to take things apart, I can understand, anyway who asked you........ :P
Post by: BigAl on 15 October 2009, 00:17:07
why would anyone in stoke know what a laptop is ?
Post by: Darth Loo-knee on 15 October 2009, 00:19:33
See big fella thats where your wrong too, sold loads of them in the pub :P ;D
Post by: albitz on 15 October 2009, 00:20:47
Showing off now youve learnt to count to four ? ::)                           ;D ;D ;D
Post by: Vamps on 15 October 2009, 00:22:56
Brilliant....... :y :y :y
Post by: Lazydocker on 15 October 2009, 00:38:16
Or try http://www.mrmemory.co.uk, I've had quite a lot from them and never had any problems... They're just cheaper than Crucial ::) ::) :y :y
Post by: omegadti on 15 October 2009, 16:23:09
before going to the trouble of adding memory - try running a registry cleaner, anti-malware and anti-virus software.  Computers only run slow when something (nasty) is clogging them up.   Adding more memory doesn't solve the original problem and 1gb should be more than enough to run most applications.
Post by: JWDF on 15 October 2009, 16:49:44
What about Readyboost   activated on a 4gb dongle  :)
Post by: TheBoy on 15 October 2009, 18:22:49
1Gb isn't really enough for vista if you have shared video.
I'd also say crucial - guaranteed to be correct module, and lifetime warranty.  Whatever, USE AN ANTISTATIC STRAP to fit it, anyone who doesn't doesn't understand electronics or computing.
Post by: KillerWatt on 15 October 2009, 18:33:54
1GB for XP, and 2GB for Vista.
Don't bother with registry cleaners, there isn't one out there that is worth the trouble of installing.
Post by: TheBoy on 15 October 2009, 18:41:58
jury still out on w7 - i reckon 1g may be enough...
Post by: yatesDELTA on 15 October 2009, 18:42:45
whats and antistatic strap?
ive been thinking of buying some more ram for mine aswell
Post by: TheBoy on 15 October 2009, 18:51:56
device to stop static discharge.  Have a google for esd and esp :y
Post by: Vamps on 15 October 2009, 21:53:31
Sounds like dropping off at a local computer shop is the best bet, I told her it would be her Christmas present...... :y :y :y
Post by: PhilRich on 15 October 2009, 22:55:03
Vamps, before giving your money away to a computer shop,installing more memory in your laptop really is a simple process, (I would recommend at least 2Gigabytes for Vista) in nearly every case it's nothing more than undoing a couple of screws in the base, removing the memory unit cover, the memory module springs up and and then the 'old' unit is simply unclipped and slid out. The new upgraded unit is fitted in reverse order. Do buy & use an antistatic wrist strap, they are inexpensive but necessary.  :yTrust me mate, a Monkey could do it! ;D ;D ;D ;D :y
Post by: BigAl on 16 October 2009, 00:28:15
aren't you getting confused with 'lap dances' ?
Post by: BigAl on 16 October 2009, 00:34:23
post up the laptop model , i'm sure someone will know the procedure, unless it's a weird one ( MacBook) it should only be 4-5  steps
1:- remove cover/keyboard
2:- ground yourself with anti-static strap
3:- insert new RAM module
4:- replace cover/keyboard
5:- switch on laptop
(optional) :- bask in glory as techno-god
 8-)
Post by: KillerWatt on 17 October 2009, 17:36:26
Just to add that you may not be able to replace the current memory with the largest you can find, it all depends on what the motherboard can handle as to how much you can upgrade by.
Post by: Dodger on 17 October 2009, 22:39:34
If the laptop is wireless networked, go to 'www.crucial.com' on the page, there is a 'scan my hardware' button.
Click on this, and agree to the terms, click on OK, and it will scan youe system, report how much memory there is already, and the maximum it will take. It will also suggest the correct type of memory (be careful.. there are two types of modules, High & low density)
along with prices etc.
This should help ensure you get the correct memory modules for the laptop.
Installing is a fairly simple job, provided you are methodical and careful. Most need just a few screws removing the cover, and removing existing memory, replacing with the new modules. (you can't put them in wrong, they are 'keyed' to fit one way only)
took me 10 min to upgrade my IBM Thinkpad from 1gb to 2gb having used the crucial site to gather the info. Local shop wanted £30 just to install my memory!!  >:(
Post by: Vamps on 17 October 2009, 22:51:20
That was interesting..... :y thing is, it says my laptop is only 1GB of memory and mine is working pretty well. Is there any other reason her laptop could be running really slowly, it is an HP :question
Post by: PhilRich on 17 October 2009, 23:20:43
It depends what she has installed on it Vamps. The longer you use a computer, the more it becomes 'bloated, with  stuff you installed because it was wanted at the time, but you may not use so much (or at all) now. Computers also come with loads of crap pre-installed these days which you will probably only use once or twice, but they take up huge amounts of space, and usually run in the background, taking up large amounts of CPU . :-/
