Chat Area => General Discussion Area => Topic started by: JohnM on 22 November 2009, 15:57:52
A (very) long-shot, but you never know!
I'm in need of a widescreen format "test card" to setup my TV. It doesn't seem that such an image is displayed anymore (24hr TV etc).
I've several restrictions and it needs to come from a pattern generator plugged in on analogue or I can record it off freeview and reply via analogue (just the way the telly service menus seem to work).
- Having a bit of bother getting the linearity correct. Any pointers useful.
Digital Video Essentials is pretty good
I would try to make my own on a PC. All you need is a regular grating that can be made with QBasic or a CAD package. You would need composite video out as well.
I presume you have a CRT TV? 'cos beware some of those have non-linear anamorphic scans that stretch the wings while maintaining square pixels in the centre. That's not true 16:9 mode though but that can catch you out.
In proper anamorphic mode a standard 4:3 testcard/grating should do. You won't get square boxes but the rectangles should be the same width/height right across/down.
I thought I had a 16:9 testcard as a gif somewhere but I can only find a 4:3 at present. It would require a PC anyway so the first suggestion is just as good if you have that.
It depends how resourceful you are I'm afraid.
(http://www.hdtvuk.tv/bbc-hd-testcard.jpg)
(http://www.barney-wol.net/video/testcardw/s%26w_tcm.jpg)
After a known transmission I can record to playback, or a pattern geny to borrow.
Anything similar tx wise to do a better setup than I've got.
Wait for the BBC HD one or get DVE
DVE as in phonebox/kiosk >:( >:(
I saw the card mentioned in HD somewhere - I wonder if my measly setup can muster some bbc hd somehow (doubting ...)
Setup not too bad at the moment - might try fiddling again the the w/end - kinda reminds me of doing convergence.
May have to wait - father in hospital and the phone line is playing up big time (just when you need it most!).
No as my first reply, excellent for setting up TVs
DVE dvd - can't use.
So far I can only setup on analogue or recorded tv and replay (not reply as original - where's the 'modify' gone?) via it's analogue o/p - seems to work okay.
When I've fathomed out how to show such an image on the telly I'll burn disc off my pc card collections.
