Chat Area => General Discussion Area => Topic started by: TheBoy on 01 January 2010, 09:11:52
Tunnie's Sky mates: "What did you do on New Years Eve"
Tunnie: "Helped a fat bloke change an exhaust"
6 hours. 6 rather hours >:(
Needless to say, all bolt bolts sheared. Knew they would. 3 drilled out reasonably OK, 4th - where I got a snapped drill bit stuck - must have taken about 3hrs. Reckon I left Tunnie with a pile of around 20 broken drill bits, and a heap of blunt ones. What a pig of a job.
Cheers Tunnie :y
I was cold, tired, and back was killing me. Got home just in time - she'd done ribs :D. Watched the Top Gear Bolivia, then tucked up in bed by 10:30. Just got up now :o
I did quite well out of the evening, found a pack of those magic sockets in my car, finders keepers ;D
I was in bed by 11, up at 6am for work :(
And one of my files....
...we'll sort out ownership in the carpark ;)
when you got a sec, i would not mind borrowing that gas powered soldering iron, really want to get that auto-dipping mirror fitted :)
Been buying cheap drill bits again!
Cheers Tunnie :y
I seem to recall breaking a bit off when drilling out the seized bolts. It doesn't half add to the time it takes! And in the cold; and on a day when it's nice to be tucked up warm.
You get a sense of achievement nonetheless?
Well done both.
Cheers Tunnie :y
Well done both.
In the sense i got rid of the fat bloke from my garage ;D
Decent drill bits did make big differance!
Once they were out, the replacement went on within half an hour.
Hopefully its settled a bit, was a tad noisey on start up
Yeah, went into the box of cheapies once I'd exhausted my supply of better ones. Did try one of tunnie's, but that only lasted a few seconds before having no tip left.
Reckon it was having to drill down the length of a snapped bit that did the damage.
know how you feel guys it taking me round about the same time to do mine as you say a pig of a job :y
if he had a 4 pot, we would have been done by 4 :P
Heated mine up with portable Oxy Gas torch came off easy. :)
Cheers Tunnie :y
Exactly why it is one job I always pay someone else to do, also avoids rust flecks in the eyes. V. painful IIRC ;D ;D ;D
Cheers Tunnie :y
Not to mention punching yourself under the chin because no spanner will fit the corroded nuts!
Cheers Tunnie :y
Doesent that just piss you off,when the bit snaps,then try and drill it back out with another,and that snaps,especially in the cold when your fingers are stinging. >:(
