Chat Area => General Discussion Area => Topic started by: Nickbat on 15 January 2010, 10:31:30
In reading this, why am I not surprised in the slightest?
Climate researchers have discovered that NASA researchers improperly manipulated data in order to claim 2005 as “THE WARMEST YEAR ON RECORD.”
In a new report, computer expert E. Michael Smith and Certified Consulting Meteorologist Joseph D’Aleo discovered extensive manipulation of the temperature data by the U.S. Government’s two primary climate centers: the National Climate Data Center (NCDC) in Ashville, North Carolina and the NASA Goddard Institute for Space Studies (GISS) at Columbia University in New York City. Smith and D’Aleo accuse these centers of manipulating temperature data to give the appearance of warmer temperatures than actually occurred by trimming the number and location of weather observation stations. The report is available online at:
http://icecap.us/images/uploads/NOAAroleinclimategate.pdf
More background at
http://wattsupwiththat.com/2010/01/14/more-on-john-colemans-special-tonight-kusi-press-release-says-nasa-improperly-manipulated-data/
Your first link doesn't work because you have a . at the end ... after pdf needs to be removed .. :)
Working link :
Hmmmm.....if we're not careful, NOAA will be building an ark....again. ;D
Coat ... ===> Door ... ===>
Pick up your wellies on the way out !!! :)
Working link :
Now corrected in original. Thanks Entwood! :y
How old are the records?
Tee Hee ;D ;D ;D ;D ;D ;D ;D ;D :y :y
Not unless hes got planning permission and building control sign off
