Chat Area => General Discussion Area => Topic started by: Mr Skrunts on 16 January 2010, 23:40:02
Title: Connecting Game Consoles to TV
Post by: Mr Skrunts on 16 January 2010, 23:40:02
I currently have the older PS2 and Xbox.
Which is the better (quality) way to connect them to the TV.
RCA leads or Scart.
TIA  :y
Title: Re: Connecting Game Consoles to TV
Post by: R.C. ™ on 16 January 2010, 23:45:21
if the R.C.A leads are Gold Plated use them .. and i can't remember if the P.S.2 had a scart port  :question
Post by: Martin_1962 on 16 January 2010, 23:51:02
Playstation 2 - VERY easy
RGB SCART
Post by: R.C. ™ on 16 January 2010, 23:54:34
RGB SCART
true .. fotgot about that .. it's been along time from playing on a P.S.2
Post by: Mr Skrunts on 16 January 2010, 23:55:44
RGB SCART
Confused there Martin.
The PS2 has a dedicated plug.  So the other end needs to be RCA or Scart (Scart is my current setup)  Allthough I know there are Scart TV adapters to plug RCA into.
Post by: Mr Skrunts on 16 January 2010, 23:57:15
Appologies Martin, just re read.
RGB Scart and not RCA as I posted.
So my current scart lead is best option.   :y
Post by: Mr Skrunts on 16 January 2010, 23:58:39
As mention the PS2 is a dedicated plug, but the TV  can be phono (RCA) or Scart.
Post by: jerry on 17 January 2010, 00:02:28
My little lad drives me crazy  with all the leads to the tv for his games. One moment its the PS2, the next the Wii then he wants to play on his old vtec smile. Back of our telly looks like spaghetti junction with all that plus leads for video and dvd!!!Oh yeh, the scart is better than the red/yellow/white connectors (or whatever these are called :-[)
Post by: KillerWatt on 17 January 2010, 01:45:47
Forget all the gold plated 'dangle berries', you won't see the difference between them and a £2.99 piece of rubbish.
As far as the "phono's" go, I'm guessing you are talking the yellow, red & white.
The yellow is composite video, and that is the lowest lifeform of all as far as analogue leads go.
A SCART lead that is wired for RGB is better, with component video (red, green, and blue phono's) being about the best you will get as far as analogue goes.
Note that not all SCART leads will be wired for RGB, some are so cheap that they are wired for composite video only (along with the audio of course).
Post by: TheBoy on 17 January 2010, 10:59:54
You want to match the metal between plug and socket. So if telly is gold plated, use gold plated. If the telly is tin plated, use tin etc.
Its an analogue signal, so poor quality cables will degrade signal. And with any signal, quality screening helps.
Hence, I don't use cheapo hong kong ebay nasties. But then, I agree, I don't use the stupid, over marketed, over hyped, tosh either.
Post by: Mr Skrunts on 17 January 2010, 11:06:23
Am with you there, on the cheapie side I allways say you get what you pay for.  On the exspensive sive I do think there is some wee wee taking on prices versus quality and performance.
Like the ,99p stero RCA leads that come with hifi seperates, I wouldnt go out and by them but I would not spend £129.99 on a pair of 1m metre interconects eother.   Regardsless of what Richersounds try to tell me.   ::)
Edit (Which they seem to have dropped as the most exspensive is now £49.99 - http://www.richersounds.com/productlist/hi-fi-separates/accessories/hifi-interconnects/4 )
Post by: TheBoy on 17 January 2010, 11:15:59
On audio, different leads can make a noticible difference, even to my tone deaf ears.  Not saying expensive are always best, just worth experimenting. I suspect its more about a good match than anything else...
Post by: Martin_1962 on 17 January 2010, 16:59:14
We have a proper lead with built in Scart - RCA to Scart is not RGB
Post by: Martin_1962 on 17 January 2010, 17:01:06
Lead quality makes a huge difference, but diminishing returns come in quite soon.
I'd say about £15 for an RGB lead before diminishing returns sets in
Post by: Mr Skrunts on 17 January 2010, 17:02:15
I was tired which is why I appologised and corrected my post. :y :y
Edit, I appologise again Martin, I cant find the post in this thread, I may have deleted it or even posted it elsewhere.
I had realised after re-reading that the error was on my side, as I was not concentrating properly and misread RGB as RCA  (My fault)  :-[
Post by: KillerWatt on 17 January 2010, 19:15:12
With all due respect TB, numerous "Which" magazines (eg, TV, Hi-Fi, etc) have conducted god knows how many tests using god knows how many cables, and the universal opinion is that the average home user is not going to see a difference between a SCART lead costing £5.99 and a SCART lead that boasts pure gold, oxygen free, etc that costs £70.
As the original question relates to a console that only outputs in analogue, any cable costing more than £10 tops is a waste of money IMO.
Post by: Martin_1962 on 17 January 2010, 20:59:39
I was mainly clarifying Scruntie, make sure you knew exactly what you want.
As to differences in leads - there are big differences between cheap leads and medium priced leads.
Mind you, you can now buy a decent Scart for around £15, about 10 years ago it was about £30.
It is little to do with the materials but everything to do with shielding with shortish runs.
The cheap couple of pound specials are horrific.
The main problem with cheap leads is crosstalk between lines, followed by picking other signals up at the ends. One common problem was picking up DVB tuner while watching DVD, replace the Scart and now OK
HDMI - if the lead is mechanically sound - that is good enough - for reasonable length runs.
Post by: TheBoy on 17 January 2010, 21:07:35
I was actually agreeing with you!  The only thing worth doing, as said, is matching the metals so as to keep the connection good (dissimilar metals and analogue is a bad combination given time). You can get decent, cheap gold plated connected cables for similar money to decent, cheap tin ones :y
I reckon worth spending a little extra on decently shielded cables, but then behind my telly is probably a bit hostile - hdmi, video console cables, mce, gigabit cables, in addition to all the usual vga, component, scart, spd/if etc.
Post by: Marks DTM Calib on 17 January 2010, 21:13:44
Metal match wont do owt.....the only adhvantage gold plating gives you is the lack of oxidisation and its quite hard....but its does not conduct well.
THE most important part of the lead is the cable construction....good quality well screened coax of the correct impedance is key
Post by: KillerWatt on 17 January 2010, 21:18:00
Sorry mate, misread your post slightly...my apologies.
That I do agree with, especially as very few here (me included) will have a set that would let them see the difference.
Having said that, those that will spend stupid money generally clue themselves up beforehand.
Again I agree, it is quite easy to obtain a decent quality shielded cable for around £10 or so that will work perfectly.
Post by: TheBoy on 17 January 2010, 21:18:57
I know we have dreadful problems at work when some idiot put tin plated memory into a load of our servers a few years back - we had to clean the contacts up about every 6-9 months due to a corrosion that built up on the connectors.
Some bloody bean counter thought he'd save a few quid  >:(
Post by: Mr Skrunts on 17 January 2010, 21:22:00
Never actually saw the point of gold plating the pins when the rest of it is just cheap cable, and then making the focal point about the gold plate being about conductivity.
Thanks for clearing that up for me Mark, the oxidisation bit makes a lot more sence to me now.   :y :y
Post by: Marks DTM Calib on 17 January 2010, 21:26:36
Yeh well, connectors pins are not tin lead either (the technology varies).....memory cards can be (or could be, they cant anymore!  ;D) as they are little more than PCB edge connector technology.
Post by: Marks DTM Calib on 17 January 2010, 21:28:20
In fact, think deeper, servers will suffer from a lot of vibration due to the cooling etc in them....hence it will be the gold pins wearing the contacts.....not an issue with a TV thankfuly
Post by: TheBoy on 17 January 2010, 21:36:01
Vibration may be an issue. Often loads of disks in servers of that era, before SANs were that popular, so they'd probably add to it.
Would the (then) high frequency of the memory make a difference?  Certainly a scrub up with switch cleaner cured it for a few more months...
