Chat Area => General Discussion Area => Topic started by: jereboam on 24 January 2010, 17:16:13
Title: Ticking phone
Post by: jereboam on 24 January 2010, 17:16:13
Not mine.  My aunt's phone line has started ticking.  Been going on for a few months and would be driving her bonkers if she wasn't 90% bonkers already.  She's asked various people what can be causing the problem, but I've got no idea who and no idea what they told her.  The only thing I can get out of her is that someone told her there was too much electricity in the flat, and she told them that she didn't have anything different from what she had when she moved in 12 years ago.  This piece of dialogue has been repeated on every (ticking) phone call we've had over the last few months.
It sounds to me a bit like the timing tick you used to sometimes hear on long-distance calls, each tick meaning that you got charged another unit, but I'm sure it's not that, as you get it phoning in as well as out.
I'm going up there tomorrow.  Can anyone suggest any tests I can do to try and determine the cause? :)
Title: Re: Ticking phone
Post by: Omegadoha, Desert Member on 24 January 2010, 17:25:19
These days anything 'ticking' usually is not a good sign. For example if I received a package and it was ticking.............
Post by: Kevin Wood on 24 January 2010, 17:49:48
Take a known good phone with you to try for a start...
If still a problem with your phone...
Take off the front panel of the master socket and plug the known good phone directly into the line, isolating any extension wiring.
If it's still ticking get BT in. :-/
I assume the ticking is only heard while you're in a call?
Post by: Plomien on 24 January 2010, 17:58:30
could be a couple of issues but if its ticking while dialling out she has switched the phone to pulse dialling instead of tone and is normally just a case of flick the switch back  :y
Post by: jereboam on 24 January 2010, 18:00:23
Not practical to get BT in, as I'm only going to be there for a couple of hours.  If they were to come while I wasn't there, I'd never find out what happened.  All well and good if the problem's fixed, but not a lot of help if it isn't.  Anyway, she says BT have already been and they told her it was "too much electricity".
But I'll definitely try taking a working phone with to test the master socket. :)
Post by: jereboam on 24 January 2010, 18:03:53
No, you can hear it quite clearly during a call.  On the last call, the frequency was about 2 seconds I'd guess.
Post by: STMO999 on 24 January 2010, 18:04:42
The speaking clock may have lost it's voice.
Post by: Plomien on 24 January 2010, 18:07:57
sounds like a crossed wire in the phone, a new phone should sort it but if its still happening on a corded line with no other equipment plugged in it will be BT's responsibility to resolve as equipment has been eliminated
Post by: STMO999 on 24 January 2010, 18:09:09
If you cure it, she will miss it and want it back please.
Post by: jereboam on 24 January 2010, 18:16:35
She's got two corded phones in the same room - she's not very mobile, and can't get out of her chair quickly enough to answer before 1571 cuts in and answers for her.
I suppose it couldn't be 1571 trying to tell her there's a message waiting, could it?
I think I'll check the wiring for the second phone.  I think my cousin put extension wiring in (at my suggestion) after an experiment with a cordless phone proved to be a disaster.  Auntie is not very good with any technology much later than a wind-up gramophone. :)
Post by: jereboam on 24 January 2010, 18:18:15
You must be my cousin, since you know her so well.  The more you help her, the worse it gets. :(
Post by: STMO999 on 24 January 2010, 18:20:33
My mum is not quite this bad yet, but is getting there. I have to phone her daily to make sure she hasn't given all her money to the poor man who wrote this very sad letter.
Post by: jereboam on 24 January 2010, 18:27:12
Auntie is 92, virtually blind, very deaf and crippled by arthritis which she's had since she was 27.  She lives in North London, about 90 miles from me.  She has managed to alienate all of my cousins who live nearer than I do, so I have to be first support these days.  If I give up, there's one more cousin in Suffolk, 30 miles further away, after which she'll have to rely on my brother.  He lives in Edinburgh. :)
Post by: Chris_H on 24 January 2010, 20:25:23
Kevin's suggestion was the best IMHO.  If you can plug a passive phone in (one that doesn't use mains power) on its own to each socket in turn and see if that is quiet.
It may be that one of her phones has gone mad.
My mum's house went to ~100volts the other day for several hours and her Lifeline unit (red emergency button round the neck) turned itself into a woodpecker on the phone line.  It has battery backup and it couldn't make up its mind whether to use battery or mains!
Post by: Lizzie_Zoom on 24 January 2010, 20:28:16
Yes, it thinks it has a crocodile wrapped round it! :D :D :D ;) ;)
Post by: Taxi_Driver on 24 January 2010, 20:37:09
Get TB to visit......i believe he used to climb telegraph poles in another life  :y :)
Post by: Turk on 24 January 2010, 23:44:40
C.I.A, MI5, the M.I.B  ???  :D
Post by: jereboam on 25 January 2010, 00:12:40
My first thought exactly! But at 92, 4'6", semi-blind, semi-deaf, semi-gaga, barely mobile and incapable of talking to anyone for more than 15 minutes without getting into an argument, I really don't think that the security forces have her under surveillance.  She's not even Muslim. :)
Post by: Turk on 25 January 2010, 00:37:47
Prime candidate, if you ask me !  ;D
Post by: jereboam on 25 January 2010, 01:21:25
I wonder - you may have something there.  Auntie's got one of those button things.  So maybe it's her that's ticking, not the phone.   :)
But I don't understand how it could be mains-powered - she's not plugged in.  Or is there a base unit somewhere that's mains powered with a battery back-up?  Her alarm system works through the intercom system for the block of flats, so I assume that the power comes from there.  There must be some sort of battery in the round-the-neck unit, I presume - I wonder who checks/services that - definitely not Auntie!
Lots to test tomorrow. :) :) :)
Post by: Chris_H on 25 January 2010, 10:56:59
If she's in sheltered housing that has personal alarm built-in then it probably isn't that.
My mother's one is in her own home and dials a call centre on her BT line so that they can quiz her and alert relatives/neighbours etc. if it's a genuine emergency.  The base unit is a modem/speakerphone combi with battery backup for 1/2hr or so. (Tunstall I believe)
Post by: jereboam on 26 January 2010, 20:14:04
OK, I've had 24 hours to recover.
As far as I can determine, and it wasn't easy, the phones themselves don't tick.  I called in from my mobile, and got an absolutely clear line on each of the 3 phones in the flat.  Auntie wouldn't let me borrow her lifeline button thingy to test whether that is causing the interference.  So no progress made.  She says you only get the ticking when the call is coming from outside the block of flats, and that all calls from neighbours and staff don't tick.  Since she doesn't actually ever speak to the neighbours, and the staff call via the intercom, this doesn't help any.  She also says it was BT who said it must be interference from another flat, but then (in my experience) they'd say anything to avoid actually coming out and doing something.
The main purpose of my visit was to transport her ladyship to the Audiology clinic so they can review how she has coped with the hearing aids she got 3 months ago.  Pointless, really, since she's never actually bothered to use them.  Anyway, she told the Audiologist that she didn't need them as she could hear perfectly well without them.  The Audiologist, a saint, in my opinion, gently pointed out that in order to communicate with Auntie, she (the Audiologist) was shouting at the top of her voice, as, indeed, I had had to do all afternoon.  Auntie was persuaded to have another try, and we were able to talk at a reasonable volume thereafter.  Naturally, as soon as we got back to the flat, Aunti removed the aids, and I doubt if they will ever be used again.  Don't know why I bothered, really.
A question: why does the traffic in Hendon contain a much higher percentage of 4x4s than the traffic in Suffolk, a place where they might actually come in useful now and again?
And the ticking?  I suspect there's a geiger counter somewhere, and Auntie has turned radioactive. :)
