Chat Area => General Discussion Area => Topic started by: Mr Skrunts on 10 February 2010, 18:08:45
Title: Air Brick Cover SUmmer/Winter
Post by: Mr Skrunts on 10 February 2010, 18:08:45
http://cgi.ebay.co.uk/Airbrick-flood-water-defence-cover-frame-Air-brick_W0QQitemZ280400570671QQcmdZViewItemQQptZLH_DefaultDomain_3?hash=item41492d292f
Have a draught in the room and want to cover the vents up outside, I know there used to be clip on ones available, also heard there were adjustable ones.  But know matter what search criteria I use Icant find any.
Whats the proper name for them.
As the link shows, the only ones I seem to be able to find are flood prevention types.
TIA.   :y
Title: Re: Air Brick Cover SUmmer/Winter
Post by: waspy on 10 February 2010, 18:22:11
The vents are there for you so you don't die of Carbon Monoxide poisoning.
Do you have a gas fire in that room?
Post by: Mr Skrunts on 10 February 2010, 18:29:45
I have one but never use it, if I can stop this fooking draught then the central heating is more than adequate.
Draught is worse as I had a flush mounted open flame fire fitted, so of course the cold it passing from there to the air vent.
Post by: Shackeng on 10 February 2010, 18:40:50
I've got a sliding one fitted for the same reason, but draughts still get through, so its Duct tape now. :y
