Chat Area => General Discussion Area => Topic started by: Mr Skrunts on 10 February 2010, 00:04:28
Got back into playing a new game but seem to have a problem.
If I click to upgrade Townhall I have a stats panel and then if I click on production and go to food (Tab) all the writing in all boxes is black or green apart from troops upkeep (Under food) which is -23000
Where am I going wrong. My food growth is 20,000+ in black on the left side of the right hand stats panel, and 6300 in green on the right. plenty of iron and stone, low on Food production is 29500.
Is it as simple as increasing the farms level, or do I need more workers.
not playing farmville so no idea :-/
Whats your population and is it in the green? (or if red then you are short of workers)
It sounds like you simply have more mouths to feed than you have farms to do it.
For info, I have 15 lv9 farms and still minus 1M food per hour....
What are your coords, I can then send the boys round to clear you out
Am starting on building the farms up
Loyalty 87/0 13% tax
Public grievance 0 Loyalty trend stable
gold 22,476 2,389 (Green)
Population 18.313 11,748 (Green)
Population limit 21050
labour force 6565
idle population 11748
Population trend stable
Plunder plunder plunder and recall troops from flat lands/vally`s and did i mention plunder
All I have done so far is build, I aint got a clue how to start plundering .fighting. :-[
Get a Lv70+ attack hero plus 600 Ballista and 600 transport.....then raid lv5 npcs for 3M food
Get rid of your farms and build iron mines and sawmills then sell the produce at market and buy food. Once you have your research high enough you could also get 500 ballistas and 500 transporters and attack level 5 npc's which will bring in 3mil food each attack plus other goodies. If you want to keep your farms you need to attack level 9 or 10 lakes which will increase your farming output by 30 to 35% each lake you have, the only problem with that is, if you have a large army and you get into a war, if your attacker is savy enough they will attack your lakes starving your army, I found out this one the hard way ::)
(http://i278.photobucket.com/albums/kk106/skruntie/00%20-%20Evony/Evony-0001.jpg)
Well your food is positive in that shot.
What heros do you have, find the one with the highest politics and make them Major
this dont seem like farmville ;D
Is this like a modern version of SIMS? ::) ::)
Mayor would be better ;D
Dont have one, dont know how to do that either, just making a hash up as I stumble along. :-[
cem, go back to looking at titties. ::) :D :D :y :y
When I started playing I was following the reward panel and what it suggested doing............I get/got bored. :-[
You'll need an Inn and a Feasting Hall, the Inn is where you recruit your heros and the feasting hall is where you can appoint your Mayor :y
On Level 3 for both of them. Best I can recruit is a level 8.
And a Lv1 of each will get you started.
Dont bother about warehouses (1 max and increasing size is NOT a priority). Beacon tower is low priority so only do these 2 once everything else is built.
1 of every other inner city item and fill the remaining squares with barracks. You want about 11-12 cottages tops.
(http://i278.photobucket.com/albums/kk106/skruntie/00%20-%20Evony/Evony-0002.jpg)
No one available to appoint as mayor :-/
Forget the level.....look for the 1 high attack, 1 high politics and 1 high intell.
The higher the better.
As a rule of thumb, subtract the level from the highest attribute....you should be aiming for a figure of 50-60 when doing this.
e.g.
Lv5 - 67 Attack, 12 Politics, 20 Intell would be a good attack hero and level up well with use.
Can I change a hero or mayor at a later date.
but my eyes catch a "farm" word somewhere else ;D
so I dont read the rest ;D
Yep ;)
It is a bit like farming, you attack other people and steal their resources to keep your army going :)
Ok, recruit charlotte as although not great, shes a good starting point.
Once recruited, go into the feasting hall and make her mayor.
A male one might be better, that way skruntie won't get done for sexual harassment ;D
sid meier , civilisation.. played continous for weeks :o
Cheeky sod, only way thats likely to happen is if see looks like our Queenie Elithabeth. ::)
From your screenshots it doesnt look like you are in an alliance.........join one pronto. That way you can ask alliance members for help and advice and it will MAYBE stop others attacking you. :y :y
Any allaince recommendations.
what server are you on.....if different to us then we wont know
83
im on server 92. same rules apply tho....look for an alliance that is more friendly to start,theres no point joining an alliance that are at war all the time because you will at some point get plundered,then all your hard work is gone. Iv slowly built up, now have 400k warriors,275k archers,and many thousands more of the rest.
Make sure your walls are heavily fortified with archer towers, and you MUST have the city gates open.
As others have said, attack level 5 npcs and only use ballistas and transporters( around 450-500 each),you dont need troops....this will soon have your resources pretty high. :y
Whats the 1st one mean. never heard of the 2nd and no transprt as yet. :-/
(http://i278.photobucket.com/albums/kk106/skruntie/00%20-%20Evony/Evony-0003walls.jpg)
(http://i278.photobucket.com/albums/kk106/skruntie/00%20-%20Evony/Evony-0003cstats.jpg)
(http://i278.photobucket.com/albums/kk106/skruntie/00%20-%20Evony/Evony-0003city.jpg)
I have no idea what you're all on about :-/
Is it like COD-MW2 & you can blow the crap outa folk :-?
I like stuff like that as well.
Used to love playing Unreal tournament, and loads of the older games as well.
ok... if you look on the map at all the derelict cities around you....find one that says level 5.
next.....click on it, you have the option to scout or attack. attack it.
as you click attack, the pop up will let you send however many men you want to attack it, all you have to send is 500 transporters and 500 ballistas, they will plunder the goods in the level 5 and bring them home to you.
IF...you dont have enough transporters or ballistas, you will have to go to your barracks and build these.
You can attacck lower level npcs, with less t and b...but obviously you wont plunder as much.
build as many barracks as you can to as high a level as you can as soon as you can.
(sound a tad like obama there ;D)
As you progress.....you will end up knocking 5-6 of those cottages dow...
what the break is all this about bring back chuckie egg
