		Chat Area => General Discussion Area => Topic started by: JamesV6CDX on 28 March 2007, 17:20:37
				Ok, the 2.5 has to go, so I'm going to sell any usable parts of it stupidly cheap....
First come first serve, no need to PM, just mention on this thread (not PM) if you want something and it's yours..
I'm happy to remove bits at a mutually convenient time, but for anything big/heavy, you must arrange your own courier.
Here we go:
Pair of known good 2.5 cylinder heads WITH manifolds: £75 the pair
160mph instrument panel: £10
Pair of good catalytic converters: £60
Inlet bridge with injectors on: £10
Plenum, with multiram, ICV and throttle body - £12
Sunroof control panel £10
Aircon compressor £30
Front multiram £7
Cruise control kit, actuator, cable, brake switch... £40
ECU, key chip and reciever: £15
Rocker Covers £10 the pair
Anything else.. silly cheap.... car's gotta go...
				Rocker covers sound good to me ...how do you want to sort out payment and delivery??
				No interest? Space is needed, it's going to be scrapped very, very soon, with lots of usable bits still on ;)
I might need a rear blind if you have it, won't know til Saturday when I can get a proper look at why mine's not working....
				Rear door speaker...
				Oil filler neck?
				Coolant Header Tank?
				header tank
filler neck
speaker and cover
All allocated
Blind is cream crackered...
header tank
filler neck
speaker and cover
All allocated
The speaker cover I need is passenger front. Speaker required is os rear...
				If no one want's the seats and they have an electric control switch I have a friend that needs one.  His M reg has retro fitted leather and the driver's seat is missing the control switch.
JamesV6CDX's CDX is a, well, CDX, hence no leccy seats (other than up/down)
				Can you find out the postage on the cats please?
Sorry just read the thread again.....you heading London way soon? I'll have em off you
				I need the plastic bits off the rear/top of the plenum.... so I guess I'll have the plenum set
Scuttle Clips
fans from the FRONT of the radiator.
ALL the pipe work at the rear of the engine around the HBV if you please....
				rocker covers. lots.
 ;D ;D ;D
Don't forget the gaskets!! Lots  ;D
				If the injectors fit a 3.0L I'll take them.
I'm 99% sure they will
Anyone confirm?
				2.5 & 3.0 injectors are different sizes (there is a stamp on the front left of the of the inlet manifold).
2.5 will work, but I'm not sure of the difference in the flow rates.
