Chat Area => General Discussion Area => Topic started by: Auto Addict on 06 April 2007, 14:02:40
Just given it a service.
When I jacked up the front wheels, there is play from top to bottom, OK from side to side.
Would that be wishbones?
Ball joint.....or wishbones but, they would need to be realy buggered to show play....
They don't look too good. :(
In all fairness, it is an old car (albeit only done 3 miles), so the wishbones have every right to look tired....
Tidy car though, despite its age :y
Just read up how to do it in Haynes....
Jack up and support both front wheels, disconect exhaust downpipe, remove antiroll bar, now you can start on the wishbones.... :(
Front wishbones on a clit are more than I paid for on my Omega :(
...and we thought Omegas were expensive to run and hard to work on.... :o
Parts for French cars are notoriously expensive....
You can say that again.
No, I'll say it for you ;D
Anyone fancy a challenge, and giving me a hand with it, please?
MOT in about 7 weeks.
Jot down the address of your nearest scrap dealer AA.....i dont mind helping and driving it there for you ;D
AA, I am always willing to help. Weekends are in short supply at present, but if nobody nearer is available, just shout :y
Thanks TB, I've got the same problem with the next few weekends at the moment, might have to be a pound notes job :(
Have you tried:
www.eurocarparts.com
I have to say GSF www.gsfcarparts.com are usually quite good, I used to use them fairly regularly.
Not found prices on wishbones to be too bad. I have just bought a pair for SWMBO's 306 TD and they were just under £50 in total.
Have you tried:
Yes, about £80 + del.
Wishbone search for a clit brings back nil.....
I don't know how this works on the clit, but if it is the ball joint on the wishbone that on many cars this can be drilled-out (it comes riveted) and a new ball joint can be fitted using normal bolts and nuts... is this the case here?
The ball joint can be replaced separately, a much easier job (only about £8 each), but looking at the wishbones, they are pretty shot with age.
Are you trying to pass the MOT or restore a classic vehicle? ;D
You better hope Mrs AA doesn't read this thread :o
Now come on...MJ....how can you call an ageing clit a 'Classic' ::)
